Hey everyone
I've noticed there isn't much into on fuel pumps etc when searching the forum so I thought I would add some of my own stuff.
So here is a bit of info that I can give. I am also after a few other opinions.
I'm a Nismo man, I have never had any issues with the Nismo 275lph pump that they make a drop in for most Skylines. Problem is, these don't have official E85 support.
I've been looking at these pumps:
1. Walbro 400lph E85 Pump (Apparently some issues with priming?)
2. Deatschworks 320LPH Version 2 E85 Pump
3. Bosch 044
4. Nismo 275lph Straight drop in
Okay... so there are other catches... like factory wiring. Does anyone have an idea on what sort of amperage the factory wiring can handle? I've been looking at flow charts and comparing amp draw with PSI etc.
Here are some flow charts.
Walbro 400lph
Random Pumps
Deatschworks 320LPH Version 2 again
The FLow charts are definitely interesting.
My intentions are:
Replace the factory fuel pump in my BNR34 with a decent pump that will do 400awkw, and from there, when its time to go for more power, I will add an aftermarket industries surge tank, and use the twin Holley Dominator 1400 pumps to feed my injectors. (ID 1300cc Stainless)
Currently installing 2 x HKS 2530s and supporting mods.
Your input would be appreciated.
The Mafia
https://www.sau.com.au/forums/topic/446806-the-fuel-pump-thread/
I run twin Walbro 255's, less current draw than the e85 pump and more flow. Still I had to upgrade the tank lid for the extra current draw and flow requirements. I ran twin feed lines, one to each rail on the VQ.
For 400+kw intank, single pump, the e85 Walbro is probably your best option, but you may have to re-pin the plug at a minimum. I have had issues with the DW pumps on ethanol, and will never use one again.
Hey mate
Can you go into more detail about the issues you had with the DW pumps? Was it an isolated issue or common?
I had a couple fail on e85 builds, and the warranty process is farked. Now I just stick to e85 Walbro's as they are cheap ($185) and they work flawlessly. (Unless you try and run water through them :P)
The e85 Walbro uses turbine tech, not gear pump. They are silent.
I like that Radium review, Thanks Tim.
I can't see a Walbro 255 being noisier than a Bosch pump though, perhaps the 044's get noisier over time? It wouldn't help that most are externally mounted I guess.
The early E85 walbros had an issues if not submerged fully, the later not so much, I have the newer E85 walbro in my 34 as a lift pump and have run it way down past the pump hieght with no issues :)
What sort of issues do they have? I've got one mounted in the standard position in tank (r34 gtr). Should I be trying to mount it further down the mount like in a 34 gtt?
Do you have problems with fuel surge under 1/4 tank ?
If not you must have a " newer " one, if so you will need to lower it or swap it out
Personally, I wouldn't waste my time with a walbro externally. There are better options.
Aftermarket industries makes beautiful surge tanks, and they also sell the Holley Dominator 1400 and 1800 external billet pumps.
Worth every cent.
http://www.aftermarketindustries.com.au/fuel-pumps--accessories-c3/holley-dominator-1400-p180/
http://www.aftermarketindustries.com.au/fuel-pumps--accessories-c3/holley-dominator-1800-p92/
Okay, assuming I don't want to make 1000hp and have a mild setup and already have a surge tank and am just looking for an external pump. What else is out there besides Bosch (have had great experiences with Walbro so would like to stick with them of possible)
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
