1. No, I don't think the 255 would be a good idea for E85 at that power level.
2. The newer ones are safe.  The 255 isn't really big enough anyway, so the question is moot.
3. Yup.  Reasonable choice.  Downsides of a truly oversized pump are excessive heating of the fuel.  The 460 isn't really all that oversized.  If you were unlucky enough to experience any problems from hot fuel, you could plumb in a fuel cooler in the return, or invest in a voltage controller.
4. Don't buy from ebay.  Buy from someone off here who you trust.  Such as Scotty.
  • Like 1
X2 agree with all points made by GTSBOY..
Those 460's are power hungry, so make sure you run appropriate wiring to them, they will eat 20amp... if its in tank remove the electrical fittings and fit post type terminals to cope with the higher power demand.
  • Like 1
Awesome thanks guys, great input!
A new pump it is then. Are there any other options besides the Walbro 460LPH you might recommend? I had a quick look but couldn't work out if Bosch makes an in-tank one.
I run a dw340 in mine, is fine for 310rwkw and has been going for around 18 months without issue. Good if your worried about current draw or fuel heating. Bad side is they are pricey for what they are and you could probably get a walbro 460 cheaper. I managed to get my dw cheap which is why it was an easy decision for me.
The walbro 255 will handle e85 although not recommended but isn't big enough for the task. Scotty has been running a pair on his vq25 stagea for years now.
Does this mean you're now keeping your car?
  • Like 1
Or from Kudos Motorsports (Skyline Specialist) or from EFI Solutions aka TAARKS (Nissan Silvia specialist but has shit tons of OEM Skyline parts too).
Both Australian, both are awesome to deal with.
  • Like 1
Thanks mate! Yeah looking at the prices the DW is probably ~$100 more than the Walbro 460. I'll probably rewire again with large gauge cable so current should be ok, however the fuel heating is of potential concern - does that happen when a high capacity pump is running at just a fraction of its capacity (ie. recirculating back into fuel tank)?
Re keeping the car, there are no takers at the moment so I'm thinking 'just one more mod' - famous last words haha. Plus maybe it'll sell better at 300+rwkw? :6_smile:
Cheers Johnny, I've ordered heaps from Kudos over the years and definitely agree.
Looks like they are listing the original F9000267: http://www.kudosmotorsports.com/catalog/fuel-pump-tank-walbro-f9000267-450ltrhr-compatible-nissan-200sx-skyline-gts25-25gt-p-1218.html
Whereas EFI have the successor F90000274: https://www.efisolutions.com.au/walbro-450-l-hr-fuel-pump-kit-s14-s15-r33
I'm guessing the F90000274 is the pick since it's newer technology?
Thanks! Yeah the wiring in the Walbro pics looks positively skinny - are you suggesting cutting it at/close to the pump and running larger gauge inside the fuel tank also?
Yep, one more mod. E85, 300rwkw will help sell, increase value of the car, i am guilty of telling those things to my wife too[emoji6].
The truth is, a stockish car at a low price is the easiest to sell.
Good to hear you're keeping and going to enjoy it a while longer[emoji106]
So are you thinking flexfuel? I would strongly recommend it for the added flexibility and never having to worry about not being able to get fuel.
Sent from my A1601 using SAU Community mobile app
The suggestion is to put new passthrough terminals onto the tank lid so as not to try to pass 1 bazzilion amps through the original ones.  And then, yes, fat wires both sides.
Lol, yes. The stories we tell ourselves.
Re flex that'd be awesome but a lot pricier with pretty much double the tuning time. I won't need the range so should be right with e85 only (famous last words).
Aren't you already running nistune? Just get the latest feature pack with flex option, add sensor and then tune for e85. Your maps for 98 are already there. Your additional cost will be the feature pack and sensor, sensor should be under 200, not sure on feature pack. Dosepipe could probably quote you for those. Just thinking out loud.
Dedicated E85 wouldn't be too bad anyways. If you go that way, make sure you save your 98 maps, so you can switch back if needed/required.
You can import your current map back on. That means you only need to sort out the E85 compensation tables. Pretty much need to tune (or lazily blanket values) for the cranking, timing and fuel tables.
Lazy tuning, add 4 degrees into the entire timing compensation table, of course a dyno would be best for these things lol
  • Like 1
  • 5 years later...
Bumping a thread.....
Im setting up my fuel set up for my track car.
Will go Fuel cell, external fuel pump, surge tank, twin fuel pumps
Its for a LS1 at around 375kws.
I want the fuel pumps to be able to accept am8 fittings as thats what i run.
any ideas?
Thanks
Why not use something like this?
http://www.radiumauto.com/FCST-Fuel-Cell-Surge-Tank-P1497.aspx
small high volume low pressure lift pump and 2x 400/425/460lph TI or bosch 39/40mm pumps be plenty
OR
2x this would work with an adaptor fitting
https://www.prospeedracing.com.au/AEM-400LPH-Metric-Inline-High-Flow-Fuel-Pump-50-1009
Edited by robbo_rb180
  • Like 1
Pump to the surge has to be able to replace what the engine can use. The main pressure pump has to do a fair bit more than that and maintain high pressure. The lift pump only has to do the smaller amount and without much pressure. Makes it a much smaller power draw, even if the delivery is, say 75% or so of the main.
Of course, if the surge tank is large relative to how much the engine can pull our of it, and you do not have long periods on power, then you can go even smaller with the lift pump.
But in general, it will only be a little smaller than the main pump.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
