After reading this thread and hearing about people paying about the same for their R32's full comp as i'm paying for just third party +fire&theft i thought it was about time i gave NRMA a call......then i found out they dont insure people in VIC, the woman told me they usually forward people to the RACV. I didn't think they would but i gave them a call and sure enough they will Insure me with a car value of $18000 for $400 odd! that is epic, i'm switching today. The guy told me it's exactly the same as the NRMA policy just branded RACV.
  • Like 1
Good stuff.
Totally agree here on Justin's thread.
What title does RACV give it?
What restrictions, if different from NRMA Vintage Classic & Veteran?
The RACV calls it : Veteran, Vintage & Classic Car Insurance here is the link: http://www.racv.com.au/wps/wcm/connect/racv/Internet/Primary/insurance/car+insurance/veteran,+vintage+_+classic
The guy i spoke to said it's exactly the same as the NRMA policy
The guy i spoke to at justcar when i called to cancel my policy couldn't believe i was leaving to goto racv, he seemed to think they had made a mistake and i was just lucky to not be refused by them.
I tried to explain to him that, No it's not a mistake and it's different to normal racv because it's the classic, vintage, veteran, but he still seemed doubtfull.
when going ahead with my new 'racv' policy the girl told me that it is exactly the same insurance as the nrma, (ie if i called nrma from nsw wanting classic car insurance she is the same person that i would be talking to), She said it's actually a better deal with the racv as i get 8 free roadside assistance call outs per year as opposed to the nrma's 2.
I'll vote for thread of the year..........certainly has made me a happy man
Good to see Shannons getting a run for their money.
however will be interesting to see this time next year with everyones renewals. Will they increase or not?
these lower premiums + high performance cars (lower exposure being limited use though!) may seem not enough 'premium pool' to cover claims (large losses) meaning an increase of premiums + excess.
however if they are on to something good and have good portfolio management - they are on to a good thing and its a winner for you guys!
maybe even someone ex shannons/lumley works there now and seen how to run this segment !
good bye shannons!! time for me to leave them too...but its only my mx5 I'd be able to take there...thats if they offer storage/laid up cover.
Pfft. I would still rather switch and save $1200.
As for thread of the year??? About insurance. Pretty boring thread. But I guess it's saving people a lot of dollars.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
