My mate makes them for 34
I have one on my car and use it for the track on my 34.
He will ship to you, my bro has a cusco one which is what this one was designed around.
http://www.gumtree.com.au/s-ad/hamersley/brakes-suspension/r34-r-33-c-34-master-cylinder-stopper/1057636608
Thanks Jake that looks like what I'm after. I've contacted the seller, hoping to hear back soon.
Just reading through this. Some great info here.
Just a question - Would it be so crazy to run two separate pads? Something more aggressive for track days and swap them back to a street pad when you're done? or will that cause issues with wear?
Not crazy at all, a lot of people do that.
However, I just found this yesterday, from Brakes Direct (GSL RallySport): The importance of machining or replacing rotors when changing pads
Basically if you go from one compound to another the recommendation is to machine the discs - not really feasible for just a track day or mountain run here and there.
Plus I doubt you're going to find separate 'street' and 'track' pads that would be of a similar enough compound?
After much contemplation I've decided to go with Remsa, I was really tempted by A1RM but I don't want the rotor wear or noise. Plus, it really is a street car at the end of the day.
  • Like 1
Thanks for the tip mate, this arrived quickly and seems like a quality part. Very easy to install, here's how it looks in the engine bay:
Haven't driven it in anger as yet, will report back once I do.
This is about half price compared to the Cusco item and I doubt Cusco is twice as good ;)
I grabbed one new of UAS a while ago in black for a similar price, does the job :)
I was considering doing an the evo brembo upgrade, alphaomega do a dogbone kit to fit evo brembos onto 355mm evo 10 rotors.
Not a bad option considering you could get it done for under $1500.
Tonba has a set of callipers up for sale on here if you are going down that path, the car has seen little use so they should be pretty mint.
I've already just painstakingly painted + purchased slotted rotors pads and lines. too late now. Stocker R34 brakes seem to hold up quite well for casual track duties it seems?
Edited by owen1r
Correct, with the right pad combo you can make them work real well actually!
Mine stops pretty hard now with the Winmax pads and DBA4000 rotors... They are chewing rotors but they have survived 4 track days now and still pull up hard... Will do one more Wakie day and then re-evaluate my braking needs as the car is predominately seeing circuit work these days, bugger all street duties...
I've got DBA 4000s and A1RM pads seem good so far but will be tested on my first ever track day on the 22nd of Nov, however since bleeding the brakes they intermittently have a soft pedal... even after bleeding 4 times over!
Edited by owen1r
You still have air somewhere mate, check it again.... Soft pedal indicates air in the lines probably....
I ran A1RM for ages, but once i started doing track in the heavy 34 they didnt hold up very well,,,, Burnt 2 sets of pads in 60 laps at Wakie :(
I take that this is for fronts only? I'm not too hot on 'mismatched' fronts and rears due to potential brake bias issues..
Anyway back to the original plan, I've got the following kit ready to go on the car, just need to find the time:
  • DBA T3 4000 Club Spec slotted rotors
  • Remsa pads
  • HEL braided lines
  • Nulon Xtreme Performance Super Dot 4 fluid
Will report back once it's all on.
  • Remsa pads
  • HEL braided lines
Yes only the fronts, I'm sure you could get some GTR rear brakes and paint them the same colour. If I bothered changing calipers I'd probably just go straight for stoptech/alcon ect.
Talk to the guys running bigger front brakes, like Richo etc... No brake bias issues with the big fronts and stock rears... As long as the pads and rotors are a similar spec you should be fine! When i go for the upgrade the rears will be staying stock...
  • Like 1
I'm just in the process of installing the rotors and saw this in the DBA instructions:
7. Fit new disc rotor to hub making sure it is indexed to a point with minimum run-out (using a dial indicator)
Do you guys normally do this? Is there a way to do this with feeler gauges?
How would you measure run out with feeler gauges?
You measure run out by setting up a dial indicator so that it is normal to the surface of the rotor, find the longest extension of the indicator (by slowly rotating the rotor until you find it), set to zero and spin the rotor. The run out is indicated by the measurement on the dial. Doing this with feeler gauges would means having to bolt some sort of straight edge contraption across the face of the rotor, somehow. Mounting a dial indicator is bad enough sometimes. This would be horrible.
You can quite possibly do it by eye. If you cannot see much runout in any indexed position then they are probably all good enough. If one looks better than the others, then go with that one. You can use a pointer of some sort to help with the eye calibration.
Thanks GTSBoy. Sounds a bit complicated without the dial indicator. I assume that if the rotor was not within tolerance there's not much I could do about it anyway?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
