i just bought r33 recently, and i dont trust the previous owner..
car is bone stock..
i just change all of the oil recently. engine, tranny, diff..
i use MT90 for tranny..
the problem its sometime grinding when i shift into 3rd gear, and sometime into 4th gear, but only happens on high rpm. it annoys me so much.
and when i change my tranny oil, i found some metal filings on the magnet plug but not much.
its shifting normal on low rpm..
is it bad synchros or worn out clutch?
those issue happens just before i change my tranny fluid.
if its bad synchros where is the recommended place in sydney and how much in total?
because its a hard job, if its clutch i can do it my self.
thank you.
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/
I'd try some redline lightweight in it first. Having pulled a 25 gearbox apart, they are fairly labour intensive. I had a few shift problems and redline seemed to help, would be much cheaper then a box rebuild and it might work. For $100 or so, its worth a go
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7390973
The teflon can break down after a while and clag up the syncro's making them worse. I only use the lightweight shockproof in diffs and (evo) transfer cases for that reason.
I would be running fresh light gearbox oil, as someone may have just filled it on thick oil. They need to be able to spin up freely to mesh at those revs. You could try Dextron3 too before shelling out for a build...
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7390988
i havent try that surfs blood thingy. wanna try it, but i just change my oil.. huh..
btw piggaz i call them recently, they charge me 1700 for labor excl. parts.. damn expensive.. but the gearbox still attach on the car, if not idk..
i can remove the box and send to them but i cant reinstall it.. dont know how to lift it, kinda super heavy.. lack of tools..
any reasonable suggestion for rebuilding?
1700 excl. parts, better i buy rebuild second hand one..
Edited by thebuuuuu
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7391256
I've had the same issues and redline lightweight shockproof ( surfs blood) made them go away. Might not be a long time fix but, mine was fine for couple years after that.
If you really want to rebuild try Competition gearboxes
Pretty sure my syncros are screwed too. I put in Redline Lightweight Shockproof and it still grinds a little at first but once it's all warmed up it shifts fine. I just double clutch till it's up to temp.
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7391601
By the way....I love threads like these. The synchros in my gearbox are absolutely thrashed. So badly that when it was first installed it would not engage any gear with the engine running until we swapped out the normal (new) oil for smurf jizz. It got better as it was driven, but the synchros are still thrashed.
And I NEVER get a crunch on a gear change unless I've made a massive fuctercluck** of it. All you have to do is know how to change gear to avoid the crunch.
**fustercluck - when you lose all muscular coordination and make a gearchange that a recently raped chicken could have done a better job of.
https://www.sau.com.au/forums/topic/448701-bad-synchro-or/#findComment-7391896
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
