few days ago I purchaced my first skyline an r33 gtst
iv been tolds its running 16 pounds of boost which I find ridiculous
as it doesn't feel or seem nothing like it, iv had a look at the ecu
and looks like a stock one to me as I said im not to well with skylines
so after abit of reading around I have a couple questions
if getting an aftermarket ecu is a nistune board still needed for a tune?
iv heard of several places that now remap the r33 ecu?
im just after a basic tune, an alternative to paying $800+ just for the nistune
just to get everything back on track for now as the car seems like running shit for that much boost..
how would this prove the ecu isn't stock though
I don't doubt the boost im just assuming he upped the boost to that amount of pressure with zero ecu upgrade or tune
which I believe is the reason why the car feels so sluggish
Because a R33 GTS-25t will run like absolute shit at 16PSI on a stock ECU. The standard ECU will dump in fuel and retard timing pretty harshly.
That's a stock R33 turbo auto ECU. Unless it has been Toshi tuned or similar (which is not so likely) then it is a piece of crap that will not appreciate being run over 10-12 psi. Massive pig richness and a complete absence of ignition advance will occur. Horrible brick wall lack of power feeling to go with it.
Also, if you are running 16 psi, there is a good chance that you will destroy the turbo any time you boost it up. They just don't like it. Too hot, too fast, too bad.
Turn the boost down to something safe an keep it that way until you can afford to replace the ECU totally.
By the way. Just in case you think you can, you cannot Nistune that ECU. R33 ECUs won't do it. The alternatives are to use an R32 or a Z32 ECU, both of which are less than ideal solutions. For the effort and compromise involved, if I were trying to tune an R33, I'd get an Adaptronic or some other suitable aftermarket ECU and just live with the defect threat, such as it is.
No. Nistune is a daughterboard conversion that you put into a Nissan factory ECU (as long as it's not an R33 one!) to turn it into a programmable ECU.
Your car is an auto? That can be a complicating factor. A lot of people like to use the PowerFC, but as far as I can remember they don't like to work on auto R33s. The problem is that there is a comms link between the ECU and the TCU (gearbox computer) that gets upset when it's not connected. The TCU goes into a sulk. I think - I don't know for sure, because as soon as I hear "auto" I go to sleep and dream of manual conversions.
yeah though so, I doubt its toshi tuned either according to a quick look up his located in NSW and im from VIC
so back the the actual question what would be a slightly inexpensive alternative then getting nistune installed?
Second hand powerfc.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
