Still have yet to have a serious convo on here lol I know some are better than others (turbos) but surely someone must of had a good run with the china gear?! A 9sec blue vlt in soom some time ago used a ebay manifold and that was still running fine after 40+ hard passes and 1000s of ks. My old gas turbine project was fine at 25psi and 630deg c. Let the haters hate and the metal fragments fly!
At least you are approaching it with a good attitude!
A guy in adelaide turbo'd and El falcon with an eBay spec turbo. Worked for him. Does that help?
Unfortunately I don't think that you will find much info on them.
Yeah it does thanks ben. Ive got a hell of a lot of mags (friends own a newsagency) seems about mid 2000s everyone from the nissans to ford 250s were into the china gear, some still are given 300+ people have bought the gt35 copy from ebay. Yolo I say so at least I can try 2nd time round and when it blows just get a garrett. I dont mind the extra work
I don't know the dude, just chatted at the track.
He mentioned that they are ok when you find the good ones. Which I imagine us hard to do.
I remember his turbo on the comp cover said "turbocharger" which I thought was funny. Maybe that's a clue to the good ones?
I watch a video the other day, a drift teams was using an cheap turbo so yeah occasionally there maybe a good one amongst the crap ones. The hunt is on, let the haters hate! Also going ebay wg shock horror! Im running a ebay boost controller, intercooler, pipe work, plenum and exhaust. Hell I should just put a massive sticker on "sponsored by ebay" haha
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
