what he said ^^^ :)
mine were gonna be getting around the 100% around the 360kw mark with an E85 walbro pump so i upgraded to 2000cc inj. food for thought
Did you check and monitor fuel pressure on the dyno?
So I've just taken this ryco filter out..
Cannot blow through it. It's clogged so bad it's not funny. As in, air goes in and doesn't come out the other side clogged .
from my experience hearing from people running E85 i dont think you get much change from 1000cc inj, after about 350kw :)
**** running E85.
is the guy that built your car running E85?
correct me if im wrong but running more fuel pressure you can use less duty cycle??
Replaced filter, 80% duty in 3rd at 7500 rpm. Not sure how that compares to 4th gear on dyno however.
This was my exact experience.
I have heard other people run into walls at ~330-370kw with mysterious fuel problems on R34's when everything else seems ok, replace the filter. At least on E85.
I upgraded to 1400's thinking my 1000's had maxxed out but found out that wasn't the case. 1000's on e85 seem to really get hairy at 400, though some people reckon they've done 450+ on them? Can never really have too much injector headroom nowadays anyway. Good enough excuse to upgrade :P
Exactly, that is how we found the flow was dropping off. You have no idea what is happening without a gauge on the feed line, and you need to be on a dyno if the gauge is in the engine bay.
Speaking of which, it seems some factory regs can be too small for the 460L pumps, they don't bypass enough. The S15 I worked on recently was tuned at 60psi at idle, no wonder the car wouldn't idle well with twice the fuel pressure it should have had. It is definitely an important test that should be checked after any major fuel system mods.
are the nismo considered factory reg ?
No, they seem to work fine. I only realised the SR regs were too small after having idle issues on petrol after installing a 460L intank. Checked the pressure and found it way too high. Perhaps the RB's will be fine as there are 2 more injectors bleeding fuel pressure off...
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
