Howdy partners,
Looking for tyres for 10 inch work meisters (measuring 11 inch wide).
I am looking at 265/40R18 mickey thompson ET Street Radial II.
Just a bit concerned that the 265 will stretch on a 10 inch rim - and they only come in a 265 or a 305.
Other option would be a NITTO NT05R which come in 265,275,285 and 295
Dont want lip hangin out from the tyre, justa nice flush fit.
Pics appreciated!
10 inch Meisters
I have seen 275s pirellis on a 9.5 which looked borderline stretched! Hense the indecisiveness
Pirelli has a very rounded shoulder. I had 265 Bridgestone and they looked pretty stretched, current 265 Falkens don't look stretched.
Track day tyres should be wider again.
I'm picking up a pair of AD08Rs 265/35 so happy days
Good choice. Seem like a good all rounder, wet/dry tyre :)
Tried to get 275 but they do not make that size, next size up, 285 .
Yokohama recommend the 265 for the for their 10" rims, I will get the 265/40 18" after I burn some rubber off the old ones.
Let us know how you like them :thumbsup:
i know its a different tyre brand but i have 265 hankook z221 on my 10" wide rims and the fitment is very flush
If you measure them they are actually about 280... I compared them to the 275 Z222 i have and the Z221 in the smaller size is actually wider!
  • 2 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
