Thanks Mate, whats another 5 months, might change it back to a 26 while I still have the parts:)
YOU WILL NOT!!!!!!!!!!!!
when a 26 comes out it gets ground up and melted down then out to a better use, like a door stop or paper weight!
  • Like 1
Just did a great big post and lost the farker :(
SO
Got the car, it is great. Only run in tune, limited to 5000rpm but feels very linear, cannot wait to get the final tune.
The Coppermix C Spec clutch is fantastic and for a clutch that can hold 700HP it is like a normal clutch to drive.
The drivetrain seems smooth but need to really try a bit harder to get a better idea?
So it will be interesting to see how it drives after the final tune, I will post results when it is done..
It is a different car to drive. :wub:
Thanks to all of the blokes on SAU that helped me :worship: :worship: :worship: :worship: :worship:
  • Like 3
I think they were impressed with the results at CRD and they are looking forward to the final tune as well.
They had "JUN" there when I got there and that is a wicked machine, going to get into the 7s on streets soon :)
I have the same bottom end ============ and thats where it ends ,haha
Fuel was better on the way home than when I drove it in for the work ?
If today was anything to judge from, I think when mine is finished it will be a very good DD :cheers:
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
