OP. Here's a tip. If you want/need new injectors and you are going to have a Greddy plenum, then just PM someone like Scotty, tell him what you want to do and buy his recommendation from him. Saves you having to do the thinking and the finding out what you need. Just tell him what ECU, what plenum, what fuel and what power level and he'll sort you out with good modern injectors.
MagicMike. In this day and age, no-one needs to run old school crappy side feed Nissan shit injectors. Especially with a Greddy plenum. It's time to move on to Bosch 1000s, etc etc.
Edited by GTSBoy
even with stock plenum you can easily mount top feed injectors & rail without any shaving of anything :)
sidefeeds are gay.. they work ok.. but on a SR20.. I find with RB25s they are gay, many gays
http://www.nzefi.com/product/nissan-rb-1000ccmin-top-feed-direct-fit-fuel-injector-kit/
Easily our favourite injector at the moment, a true 1000cc out of the box Bosch injector, not a 550cc decapped one like the ID1000s, so the spray pattern is great.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
