WELL HERE WE GO....
Bought GTR
After 3 months Motor went Bang, cracking pistons, shattering valves, it did a really good job.
Fully rebuilt engine, decided to leave standard turbos because yolo (just for the run in stage, kesh was low)
On the way home from Full rebuild running the engine in and not boosting it i spat exhaust wheel of one of my turbos out my exhaust.
Got new turbos
AFM died on the way home.
finished run in
TPS died on the dyno
Fixed TPS
Split a rad hose
Fixed hose
ran for a while
Lost half my oil
Fixed everything again all is running better than ever!!!
until.
Got shit fuel two weeks ago and was misfiring on 14psi...
Cracked the shits, Haltech, no AFM, and E85
what will go next?
#GTRlife
Bought and installed brand new sard 540cc twin spray injectors, came in as a kit specifically for rb25, they are white
Engine ran rough, also sounded like Wrx throughout the entire rev range
Tried trouble shooting think one may be faulty, bought a spare injector and still the same
New owner put it into a 2jz aristo, punched the numbers in ecu, fired up, all silky smooth... They're a waste of time on skylines but fine on toyotas
Sard 550 reds were good in my old car
WELL HERE WE GO....
Bought GTR
Got new turbos
finished run in
Fixed TPS
Split a rad hose
Fixed hose
ran for a while
Lost half my oil
until.
what will go next?
#GTRlife
Hi Anthony
Made my eyes water :(
Seems I need to post a TLDR version here.
Will maybe write it out if I can remember it all
Had car for 7 years
is a daily (lol)
Done 27,000kms total in 7 years
This car is on
its 2nd chassis
its 5th engine (and third rebuild)
its 9th fuel pump
its 2nd diff (and set of axles!)
its 3rd set of suspension
its 4th? transmission
its 3rd ECU
its 3rd turbo
its 3rd (sort of) manifold
its 3rd fuel tank
its 4th set of tyres (in 27,000kms?)
its 3rd set of brakes (as in set of front calipers, discs)
its 3rd exhaust
as you can imagine, the non TLDR version of this is very long
..and still going
  • Like 4
Holy Shit !
Hope you like working 3 jobs. :3some: to pay for this lot?
I take it you also track the car or you would be in jail by now going through that lot on the road :woot: or do you run sly grog :pirate:
Is it still your DD, got some pics?
Had car for 7 years
is a daily (lol)
This car is on
its 2nd chassis
its 9th fuel pump
its 3rd ECU
its 3rd turbo
its 3rd fuel tank
its 3rd exhaust
..and still going
Wow Greg that is true dedication! Out curiosity, have you worked out total cost of ownership ($ per km)? I've got mine for this and the previous car and they ain't pretty...
Holy Shit !
All the kms done were cruising kms below the speed limit, off boost. Well not all, but relative to most people on SAU I really do drive like a grandpa.
I'd like to take it to the track one day, but the car has never been working.
It is currently sitting at an engine builder shop, with the engine entirely dis-assembled.
As for $ per KM, it's certainly somewhere around $2
$2 a KM , haha that would stop you going to the shop for an ice cream :woot:
If what you say is true (bullshit I think) I would change mechanics , maybe you are using a carpet layer to do this work for you or :pirate: ,LOL
  • 3 weeks later...
But you have more money than sense:)
How come you have not got it right by now, 5 motors???
If mine is not as I want it , I will be sooooo pissed off :(
But I am sure it will be and then some :)
I'd like to put in my $0.02c and suggest.. the f**king silver dash. I mean seriously. Half the interior photos and sale threads et al have it, and it's infuriating. My car is also tarred with this.
Why yes, I did let my kindergartener suggest and paint my interior!
I'm currently sitting at $10 per KM hahahahahaha]
When this build is done I will be around $27 PK , only because I have not done a shit load of Klms
Whoa!
Ok so the Skyline's sitting at around $1.25/km and the Monaro was $1.90/km, all inclusive.
It doesn't sound that bad until you consider that at $2/km:
  • Melbourne to airport return costs $100 (50km)
  • Melbourne to Geelong return costs $300 (150km)
  • Melbourne to Sydney one way is $1,760 (880km)
Oh well, cars. But ouch.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
