Extra Capacity Sump Needed With Any Hi-Flow Oil Pump ?
Ah coolant overflow, previous discussions make way more sense now lol. -
ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so. And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
