Fuel set up:
Factory HICAS hard lines
1150cc Bosch injectors (stainless steel internals)
3L surge tank (anodised)
Holley Dominator 1400 fuel pump (ss internals)
Holley FPR
Earls 175 GPH fuel filter
Cost = $2k
+ in tank pump
Thanks mate. Will get a quote
I think issue comes with time...I've been put onto this to help counter the breakdown/corrosion/gumming
http://lucasoil.com/products/fuel-treatments/safeguard-ethanol-fuel-conditioner-with-stabilizers
Haven't heard that...anyone had any experience with this?
well as soon as I have issues I will let you know but so far so good.
Having said I've put 98 in it for now.
When I put E85 this is the lubricant I put in to help the protect the engine
Smells awesome too
Smells awesome too
Thanks Anthony, great input as always, appreciate it.
On another note, quick question re front pipes:
Does anyone do a 2 x 2.75in into 3.5in front pipe??
HKS do 2 x 2.75in into 3.35in which is pretty fkn annoying :verymad:
  • Like 1
Midori Seibi do front pipes 2 x 2.75 to 3.54 (90mm) if that helps
available in stainless or Ti (I am looking at the 90mm Ti myself)
http://www.perfectrun.jp/src/detail.php?pid=201002&pname=SUS%20FRONT%20PIPE&maker=MIDORI%20SEIBI&maker_id=201&result_mode=pmk
Thanks again!! Don't know how I missed that one ;)
Mmmm the HKS one is about $160 cheaper compared to Midori Seibi.........
Do you currently have the ss Midori? I would be interested in it if you are going to upgrade to TI....
Fuel system set up is now ordered. Went through Julian @ Aftermarket Industries. Very helpful and from what I've heard very high quality products, should arrive after Christmas!
nah. I have Ti bro.
I would suggest also getting an aftermarket front diff when you put it in... The system munches standard ones :(
  • Like 1
Thanks for the heads up Simon, appreciate it. Are you running it or have just heard of a few cases?
I have never had a front diff failure...has anyone out there had first hand experience with this? I'm wondering how much damage is done when they fail....?
If just strips or munches the diff gears and makes bad noises then I can live with that but if it's going to destroy the sump/diff housing as well that's a different story!! It would be dump not to upgrade while the motor is out now and save the heartache!
I see JustJap have the Quaife diff on their website for $1,800 which is no doubt not cheap...
http://justjap.com/quaife-atb-helical-lsd-front-differential-nissan-skyline-gtr.html
Who has purchased one of the above and where was the best deal??
Bit of an update below:
Head off and will continue stripping
Sump off and getting cleaned up for extension
Final clean to do then acid wash
I've personally done 2 front diffs in the last year. I'm lucky they have just died but it's not uncommon that they can punch out of housing and take out the sump.
I would suggest a Quaife or go a Ruzic diff controller if you want to keep the stocker
Edited by SimonR32
what diff you put in Simon?
Quaife is by far the better option imo
Looking good, I have seen a few fail on the race cars, one ripped the diff housing off the sump :(
I got my Quaife from Palmsdale NZ, wasn't $1800 :)
If you are taking the valves out, get a spark plug socket with the magnet inside, sit it square on the retainer and give it a good quick hit with a hammer :D
  • Like 1
funny you mention buying a quaife diff from Palmsdale as I got a quote from them and is costing $1700 postage not included
Sourced my quaife diff from power tune Australia cost me 1500 delivered
  • Like 1
  • 3 weeks later...
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
