Got the head and block pulled down and dropped off to the mechanic so the real work can begin
Parts have been slowly coming in, will get some photos up asap.
gonna keep standard bore Robbie or something more exotic?
Few Tomei bits n pieces now in the house :yes:
Been waiting on the sump baffle for the sump extension, can now get this under way! 8.5L here we come :thumbsup:
Anthony, it's looking like we'll be going to 87mm.
N1 block
Nitto pistons
Nitto H beam rods
Nissan 'long nose' (revised) crank
Tomei pump
  • Like 1
  • 3 weeks later...
Soooo pumped with this purchase :banana:
Roll cage arrived last week as well :D
Looks like we will be going to a new N1 block...hopefully get that ordered tomorrow but will be a 3 week wait from you know where
  • Like 2
Looking good mate keep it flowing. Id be sticking with 86mm pistons so you have meat in the block left to go upto a 86.5 and then 87mm piston if the motor is damaged. The benfit will be the block will have been heat cycled many times by then and alot stronger than boring a new n1 block straight up. Really shouldnt have too many issues either way. Also you wont have any maching headaches and expenses if you can find 86mm forged pistons, i havent really looked into it. I think the standard oem pistons arent probably a bad thing with the cooling channel.
How much was the seat and rails and who did you order it through, a very nice bit of kit there! The willans harness will go nicely with it
Also nice looking tomei baffle, although i prefer the nismo one the tomei will obviously do the job. Who is doing the rest of the work on the sump for you and and what cost. Are you planning to run the drain/vent to the head or just running one vent from the sump straight to a catch can?
  • Like 1
Cheers Mick. Yeh mate spot on. It's looking like Arias 86mm pistons will be the go and going to run them with Nitto H beam rods
I purchased the seat and harness off here! Cost me $900 including the harness. It was a local purchase as well so no cost for freight! I believe Rocket Industries carry them but...
Yeah I can't justify the Nismo price tag for the baffle...we modify the Tomei one to suit the new winged/extended sump as well and it's easier to do so with a Tomei one
And yep will be running a Nitto head drain. It will be the same set-up as [1 OF A] but less refined ha. Just some black rubber hose, push on fittings, and no fancy RIPS catch can!
I've got a local guy in mind for all the ally work just gotta get over to his place and nut it out!! Never enough time...
Ok it's done
Nitto H beam rods
Nitto 86.5 pistons
Nissan N1 block
ALL BRAND NEW!! :D:D:D
Now onto getting the sump sorted...
So I now have a used N1 block for sale ready for sleeving if anyone is interested
  • Like 1
how much for the N1 block? out of curiosity lol
$2,440 inc GST
who welded your intake pipe?
Hey mate, just a local guy here in Bris...think he does a few of them
Forge Performance in Mount Baker, SA are doing them for $100 pretty sure
yeah im onto Josh for mine.
looking forward to more of this build.
Nice one Glyn. Should really start ramping up now!! :P
Looking good robbie, was the block from justjap?
Cheers Mick, no mate just direct through Nissan as it was cheapest (trade price). Just have to wait a couple weeks for it as ex Japan
mmmm new nitto goodies....
Yehhhhh boiiiiiiiiii!! :cool:
Can't wait to see how old Quaifey performs...have heard nothing but good things!! Should put less stress on the block as well which can only mean good things
couple more random bits
Mine is getting its first run this weekend... Interesting your comment about the block, what's the theory behind that?
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
