Hi Guys,
I've got r32 GTR, i've bought it with HKS coil-overs and a Nismo front sway bar installed as the only things done to the suspension, the bushings etc are all unknowns, probably 20 years old. The car is my primary car but isn't my daily due to my work, and it gets used for lots driving out of town, and will be used for occasional track days, nothing serious though.
I've decided to redo all of the suspension bushings and install the basic set of adjustable arms, as this will probably suit my needs well enough, budget isn't the #1 issue here luckily so no having to make do with camber bushings etc. Anyway, i've pieced together a list of parts but i'd like some feedback on it, to make sure i've made good choices and to also make sure that i've not made any glaring mistakes (eg getting incompatible GTS-T parts) or missed something entirely (something on the front uprights?). Without further ado this is my entire parts list:
Arms
Front Camber
http://www.hard-race.com.au/index.php?route=product/product&path=25_714_722&product_id=238
Front Castor
http://www.hard-race.com.au/index.php?route=product/product&path=25_714_722&product_id=845
Rear Camber
http://www.hard-race.com.au/index.php?route=product/product&path=25_714_722&product_id=185
Rear traction rods
http://www.hard-race.com.au/index.php?route=product/product&path=25_714_722&product_id=183
Swaybars
22fr 24rear whiteline
nismo 22mm front already in leave there do rear only?
http://whiteline.com.au/product_detail4.php?part_number=BNK009
Bushes/ball joints
Rear subframe bushes
http://www.hard-race.com.au/index.php?route=product/product&path=25_30_622&product_id=486
diff supports, whiteline fr rear
Verify diff mouting type
Front LCA inner
Stock lower innner ball joint
http://www.kudosmotorsports.com/catalog/genuine-nissan-pitwork-ball-joint-front-lower-inner-genuine-nissan-nissan-skyline-r32-gtr-gts4-r33-gtr-gts4-r34-25gt4-p-280.html
Front LCA outer
Stock lower outer ball joint
http://www.kudosmotorsports.com/catalog/genuine-nissan-pitwork-ball-joint-front-lower-outer-genuine-nissan-nissan-skyline-r32-gtr-gts4-r33-gtr-gts4-r34-gtr-25gt4-p-106.html
Steering rack
Poly bushes. Get stock rubber ones?
http://www.kudosmotorsports.com/catalog/superpro-parts-steering-rack-bush-kit-superpro-nissan-skyline-r32-gtr-gts4-r33-gtr-gts-gts25-gts25t-gts4-p-1242.html
steering rod ends/ball joints?
only thing required for steering rods?
http://www.kudosmotorsports.com/catalog/genuine-nissan-pitwork-outer-tie-rod-end-front-nissan-300zx-z32-071989-021996-skyline-r32-gtr-gts4-p-1259.html
Rear LCA inner
Poly. Rubber probably better for road use?
http://www.ebay.com.au/itm/Nissan-Skyline-1989-1994-R-Control-Arm-Lower-Inner-Bushing-SuperPro-SPF1639K-/190916552502?pt=AU_Car_Parts_Accessories&hash=item2c73836736
Rear LCA outer
stock ball joint
http://www.ebay.com.au/itm/2-REAR-LOWER-BALL-JOINT-NISSAN-SKYLINE-R32-90-94-/190649239948?pt=AU_Car_Parts_Accessories&hash=item2c6394898c
Outer Camber arm/UCA+Outer Traction rod
same as camber arm, can use other pair for that?
http://whiteline.com.au/product_detail4.php?part_number=W62546
other
Front wheel bearings
Decent brand?
http://www.ebay.com.au/itm/TWO-REAR-WHEEL-BEARING-KIT-NISSAN-SKYLINE-R32-GTS-R32-GTR-4WD-R33-GTS-4432-/191386267395?pt=AU_Car_Parts_Accessories&hash=item2c8f82af03
Rear wheel bearings
Decent brand?
http://www.ebay.com.au/itm/2-FRONT-WHEEL-BEARING-KIT-NISSAN-SKYLINE-GTR-4WD-R32-91-93-R33-R34-95-01-4574-/201004989682?pt=AU_Car_Parts_Accessories&hash=item2eccd4bcf2
Hicas delete kit
http://www.ebay.com.au/itm/HICAS-ELIMINATOR-LOCK-BAR-KIT-R32-R33-R34-SKYLINE-GTR-GTST-GTT-S15-180SX-/301363010419?pt=AU_Car_Parts_Accessories&hash=item462aa29b73
Secondly, i'm having a hard time deciding on sway bars. A few options, go the White-line drop in kit which has adjustment so i can mess around and dial it in, go a Cusco non adjustable kit and hope it works, or leave the nismo front in and get a new rear only. Honestly i'm not really sure what to do. I don't know the spring or damper rates of the coil-overs either, which would factor into the choice (stiffer springs means stiff sway-bars as far as I know)
Thirdly, is there anything else i should be looking out for when I eventually do the work, apart from the obvious like bent LCA's etc.
Any advice or wisdom would be appreciated.
https://www.sau.com.au/forums/topic/450525-bushing-replacement-sanity-check/
I would never trust any of those nasty looking I shaped adjustable front arms. There are others out there for >$500 which look stronger. I had thought that UAS used to do some good ones, but they appear to only have I shaped ones too. One thing they do have going for them is that they pivot in the centre section, meaning that the horrible loads that get put into R32/Z32 upper arm bushes is relaxed. Much more $$ though.
Your front caster arms will do, but I'd go for the ball ended ones. Much better (even if not legal, or as long lasting, they are so much worth it).
Rear arms are the right choices.
Do 24mm adjustable bars front and rear.
Poly bushes are fine everywhere that there is rubber. Extra noise and harshness not a big problem. Note that you won't need them where you are replacing arms (the upper rears and radius arms in particular).
There is a recent thread on poly rack mounts.
HICAS eliminator is 100x better than a normal lockbar. Do it.
Edited by GTSBoy
I got the SRI red ones from Just Jap, been in the car for two years now. I can't compare to standard because my car came with aftermarket arms with destroyed bushes.
BUT, the arms have been fine. I have those Hard race ones sitting in the garage, they look better built than the red SRI ones.
Thanks for the feedback
Re front castor arms, you mean these? How exactly are they better/different?
Whiteline doesn't do a 24mm front for ze GTR. Will weigh up options once i know my spring rates
When you say better, you mean more firmness, feed back etc, but probably a little more harshness/noise? I guess i should just Man up and deal with it... Just noted the thread on poly rack mounts, that solves that.
expensive list, eh? but you will love how much better it feels once it is back to factory tightness or better.
If you want to tighten up everything you also need:
ball joints for the rear steering arms at the rear hubs. They flow out and leave the rear end unstable
Inner and outer rod ends for rear steering (still need them in good condition with HICAS lock kit)
inner rod ends for the front steering
The car handles a little worse than my old GTS-T, and boatloads of extra power can only make up for so much, so i'll be glad once its all sorted.
Got any details on the inner rod ends, all I could find was rear ones?
Only ones I can find are Taiwan spec. link
As its just a straight bit of metal with a ball joint on the end... how bad can it be...? Should I go down to Nissan parts and get genuine ones, or is there another better option?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
