If it's a stock cam Rb25det, 120 is way low, must be very poor when driving off boost.
I'd think hard about doing it up as opposed to buying a 2nd hand engine, something coming with a compression test at least.
Unless you're dead set on building up an engine, you'll quickly find parts and labour costs will exceed the cost of a replacement.
Have you tried another gauge? Maybe that one just reads low?
I agree with Johnny. If it's still running well just keep flogging it. A stock replacement engine is cheap enough.
Damn straight, that's what I'm doing with my 400 000km motor, seems to like getting thrash at the track too.
23 psi seems like a good number lol
  • Like 2
Two different gauges, im thinking a 2nd hand engine soon. Timing is not out. Its sluggish down low but puuls ok 80kmh onwards.
is this based on experience with other RB25's with similar setup or just your feel on this as the first RB25 you have driven?
Nonetheless, 120 is pretty low. Needs more boost to compensate ;)
Incidentally how many k's on the clock?
ideally you would do a leakdown test. Alternatively you can just squirt a little oil in the cylinders and see if the compression comes up - that indicates that its rings rather than valves.
And do pull the cover off and check the cam timing.
Yes heaps of people are driving tired engines. The main thing is that the compression readings are close together as yours are. Are you using heaps of oil? Your car could go for years (or not).
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
