Just wondering if wheel spacers for a daily driven are a good idea. Been offered some good rims for a good price. They hit my front struts and i will need to use spacers. The seller is throwing in some flat 5mm slip ons with the wheels and they will be enough to clear the struts.
Been reading all sorts of stuff on the intergoogle and basically the answers range from no, never use them to yeah 5mm slip ons are ok.
https://www.sau.com.au/forums/topic/450709-wheel-spacers/
I have used 5mm spacers for 5 years on the 25G with no probs.
Exactly this whole spacer do and don't topic is stupid. Ofcours is your running bigger than 5 mm slip ons I would either use extended bolts you give the same amount of thread or the kits that use the hub bolts to bolt on then have there own bolts to give the same thread about such as the h&r kits that ate hub centric
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7426079
Sorry not intending this tread is stupid it's a valid question but it's commen sense that if you have less bolt thread than is intended past 5mm your gonna run its some serious problems like loseing a wheel. Not fun!!
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7426081
I forgot to say that the spacers were used so I could fit the 2 pot calipers from the RS4 to the N/A 25G. I also used the booster and master cylinder
The RS4 got 4 pot and a bigger booster and larger master cylinder.
  • Like 1
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7426179
I'll give hub centric with stronger, extended bolts a try. I want to get away with the minimum spacer size as i'm not after a bling, flush look, just gotta get bigger wheels than stock cos of issues sourcing front discs for my RS as it is rwd. Front discs are on their last machine and probably a whole heap easier and better to upgrade. The wheels are 3 piece 18x8 front 18x9 rear which i understand wouldn't be a prob for the awd guys but is an issue for the rwd.
Something else i was wondering about is the wheels are heavier than stock, which would obviously increase rotational mass which has an effect on acceloration and economy. Has anyone with 18's on their car noticed this effect?
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7426723
Depends how much heavier.
I went from the stock 17x7 with stock brakes to cast 19x9.5 with front and rear Z34 Akebono brake kit. Not sure that the wheels would have weighed much more than stock, but add the brakes and I am around +20-30kg over stock and have only noticed a 0.1 km/L decrease - going by my fuel economy screen of course.
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7427878
Only use forged wheels myself so they are definitely lighter than stock. Not sure about rotational mass affecting acceleration and economy. Total all up weight of the car is the key and a few more or less kg on the wheels won't make that much difference The effect of increased unsprung weight on the handling is a whole other story..
Are you sure yours are heavier than stock?
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7427949
I didn't weigh them on scales, just picked 'em up one after the other with the same arm when i was checking the fit. Re the increased mass, the way i understand it, the further the rim is from the hub, the harder it is to spin. Think of an ice skater doing a spin, to increase the speed of the spin they bring their limbs in towards the centre. I also found this when i was doing a bit of searching.
http://www.caranddriver.com/features/effects-of-upsized-wheels-and-tires-tested
I'm not sure if i would notice anything going from 16 to 18 inch judging by these times, but the difference is measurable. I guess i'll found out in a couple of weeks when i get some new tires on the rims and get'em bolted on. If anything, knowing they may be having an impact would probably play on my mind more than seat of the pants feel.
I was just simply curious to see if anyone else had noticed anything different acceleration wise when they had upsized their wheels.
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7427978
Not on my stag, but on a previous car i went from 15s to 18s and noticed a substantial decrease in acceleration. Well enough that you could feel the difference.
So yes it is possible that it will decrease perforce depending on weights and overall rolling diameter.
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7427982
What you are saying is the higher gearing not the extra weight slows acceleration but I don't believe it makes stuff all difference. Besides the nominal height might go from 16 to 18in but the increase in diameter will be less because normally you will use lower profile tyres.
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7428116
Unsprung weight , I doubt if you will notice the difference , unless its a race car and you are looking for everything that you can get . get a set of bathroom scales and check them , at least you will get a rough idea . I made my own wheels for the Exa 13x 10 weighing 2.5 Kg, because I couldn`t bye anything . The only real difference between 16,17 ,18 etc is the larger the wheel the smaller the profile and the harsher the ride.
https://www.sau.com.au/forums/topic/450709-wheel-spacers/#findComment-7428118
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
