Like me the struts have passed the UBD. The bonnet slowly came down if not propped up. I was under the front for an oil change. The bonnet was up but not propped. I was getting out from under and reached up to the top of the grille to get up and
F@%&! The bonnet came down on the back of my hand. I tried to open the catch but the bonnet was fully locked.
I screamed for Mrs66 she opened the release and I got my hand out.I envisioned all my fingers either crushed or amputated and a bloody mess. But the Gods had smiled on me. No blood, no broken skin even. I whispered a silent prayer of thanks.
That was yesterday. Today I fitted the spare pair I had.
https://www.sau.com.au/forums/topic/450884-ageing-gas-struts-beware/
Just incase anyone is interested, you can actually get them re-gassed. I had mine done at my local Auto One, but I'm sure other places must do it. Had it done a couple of years ago and they're still going well.
- Lance
  • Like 1
lucky man!!! Could have been ever worse if the car was running.
I typically hate regassing struts, they leak out for a reason (seals perished/shaft scored/torn seal) and re gassing is a patch fix...If think you can generally get a pair of new struts for about 50-60! Regas is about 40....
Edited by DMM
I believe I replaced them with a pair of generic maxima struts. Cheap and very strong.
Doing the rear tailgate is still going to be a trick. Other than regassing its a custom job to make new ones. I don't mind making new brackets, but finding similar struts is trickier.
On my old 2001 M35 the boot would try to push me in the back with my bike on cold mornings, rest of the time they worked nicely.
Pity they are not like the Toyota Hiace ones that you can rotate a section once open to lock them open.
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
