Looks great!!
I want that box so bad. What did you use to cut it into shape?
Looking good mate.
Thanks for the kind words guys!
Regarding the cutting of the shape, I tried tin snips but the metal was too thick so I drilled holes and used a jigsaw. The metal was flapping around and I was finding it hard to cut so I rested it on a drum of power wire (the stuff sparkies carry around) and used that to support it on either side while I cut in the middle moving the material instead of the jigsaw because of the limited space.
More updates coming soon! I ordered something small but cool for the car :)
that is one stealthy build!
nice build man :)
Thanks mate, I'd like to eventually go top mount for ease of access but for now stealth it is.
he ordered a dose pipe! wooooooooooooooooooooooooooooooooo
One day, when NSW HWP go away *cough cough* - Never
Ordered some more parts from Kudos to fix the cooling problem where the car runs super cool for no visible reason.
Thermostat - because the one in there which was also new MAY be faulty but I would rather be prepared
Thermostat housing - because everyone complains how fragile they are. Again would rather be prepared
Gasket maker/goo - I ran out of the old stuff I had
OEM Radiator cap - Just another thing so I am prepared
DB574A4F-4D47-4791-93D6-D6D1B288E467_zps
My bosses must be getting sick of receiving car parts for me (get everything delivered to our office)
As I have the Pulsar I wont be in a rush to get this done so I'll put my car in the garage this weekend and take my time.
Ordered some more stuff from GKTECH
They now sell the solid shifter bushing for R33 GTST's which they stopped selling years ago. Bought that and the shifter springs again that I bought a while back. I completely forgot to remove the two rounded bolts last time I had the gearbox off - This time I'll lower the box which I didn't think of doing last time and get one of those rounded bolt sockets on it or a good pair of vice grips. Not sure why it was so tight last time though
Stay tuned - I have some work this weekend on the car planned
My neighbours don't like how loud my car is so I spent today at a friends house working on our cars and changing my thermostat (had to run it to bleed it and my neighbours hate it)
Found the issue with the cooling, changed the thermostat housing, thermostat, bled the system etc. Heater pumps hot again (was warm before at best) gauges read right and the data logging shows the right reading.
I'll do a quick DIY for the thermostat change because I found a good way to locate it without causing the problem I had again. I'll explain below anyway.
B8A95740-195A-4A3B-809F-F21422097306_zps
F13F3FFB-5626-4E58-9E8C-9CE6DC4168A1_zps
B6615119-D973-4D23-9F21-D27F1FDDFD37_zps
8500ABAC-6A08-4E9E-AE7A-B931B49366B1_zps
08861589-3E82-412A-AD3B-F78B4DF659F4_zps
The issue I was having that the thermostat didn't locate in the block properly. This was caused because when I tried to locate the thermostat originally I couldn't line the bolts up without bumping it (sealant grabs it and moves it etc) around causing the thermostat to lose its seating in the block.
To get around this I got two long bolts with the same thread pitch and cut the heads off them, screwed them into the block and placed the thermostat housing over that meaning it was straight and I couldn't possibly bump the thermostat out of the block again. Put one bolt in, torqued it down then removed one stud and repeated.
More goodies coming - I'm broke until pay day now but atleast my car loves me.
Some pics from a few weeks ago when we had back burning in Sydney - Went down the coast in the hopes that it would be less smoky down the coast but it was still pretty bad.
R33%20GTST%20Jamberoo%20Pass_zpscxoh2ian
Still trailing daytime photography so these are the two of about 100 that I took that I liked. Heading to Bathurst this week for a drive as I have a couple of days off so I will take some more pics up there too.
  • Like 1
Worked on the Pulsar yesterday and the Skyline today
Pulsar got new brakes, driveshafts, brake fluid and some general cleanup
I went to change the shifter bushing today on the Skyline but the bushing wouldn't seat low enough to get the circlip into the top of the gearbox. So after lots of messing around I finally wrestled the shifter out and put a brand new OEM bush on.
Pics below
Found a car cover at Supercheap
One more because I thought it was funny
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
