Hey guys, i recently picked up a c34 Stagea series 2 RS Four S Dayz edition . I got this completely stock a few weeks ago.
10849839_766900880056693_709592562314056
10801794_766900933390021_369692916991287
10418917_766900960056685_981780862303257
10849930_766901010056680_925095451968798
1526396_766901036723344_7135578613636870
10805767_766901053390009_531910469256076
10847896_766901086723339_424902828485210
1517533_766901116723336_2923269923810884
the mods have started . first mod was to fit the R34 GTR front end , I've always loved Stagea's but never liked the fronts on C34, that was quickly fixed by the front swap, comprising of :
genuine R34 GTR bonnet, front bar and headlights, Modified R34 GTR reo, and Masa motorsports conversion guards :
10850304_766901153389999_910459790115006
10849765_766901186723329_563542543602668
10357181_766901216723326_239661420468691
10424325_766901240056657_401040530307880
11361_766901256723322_282134691654411782
10645087_766901280056653_128553219466225
13826_766901323389982_651233323238305608
1908211_766901353389979_1188113951399964
10846024_766901373389977_533752640753253
10644847_766901403389974_882877404639221
10367591_766900936723354_666542419395360
front finished, sorry for the iphone potato pics :
10391056_761252593954855_578911880337145
10336640_761252693954845_118500943871505
the front was dontated from a C34 front cut that had already had the swap in Japan. The same car also donated its Fujitsubo cat back, Greddy front mounted intercooler and Apexi pod ( as the HKS Death filter was crumbling) . Ive also fitted BC coilovers and the 2005 G35 Coupe 19's .
soon to come are Autech RS260 side skirts , rear bar and rear wing, then a full respray over christmas.
Ill update as this as the build continues. thanks, Ben .
Edited by mechanicalstig
  • Like 10
https://www.sau.com.au/forums/topic/451482-mechanical-stigs-c34-stagea/
hey guys, its getting a color change , not entirely sure on final hue yet but it wont be a radical change.
future plans are pretty open really but above all needs to be a practical daily so will get more cosmetic mods than performance.
few things o nthe cards are a haltech platinum plug and play and flex tune and put the 3 inch dump on. apart from that nothing is really locked in .
Thanks,
Ben.
  • Like 2
Yeasss going all out with the haltech, is scotty going to set all that up for you? I'd love to do exactly that in my 34 but to much $$$$!!!
Please don't paint it like Midnight purple, or bayside blue... do a colour that every other import owner hasn't done yet!
Heh, I love the colourful graffiti language on the burnt down building.
Looks the goods! R34 front end is best, the rays wheels in white looks great.
Edited by M35woah
  • Like 1
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
