yo
I was driving my mates r34 gtt today it has 330 kw blah blah, with a heavy duty clutch and standard drive train.
As i hit boost in second gear it broke the passenger side rear drive shaft. This is the second time its happen on the same side. The drive shaft has lasted two months tops since its been rebuilt.
as any one else had this problem ? does he maybe have a problem with his diff causing it to break on the same side ?
thanks in advance ?
https://www.sau.com.au/forums/topic/451743-breaking-rear-drive-sharfts/
Just because it snapped coming on boost doesn't mean that's what killed it, the damage was done (not long) before the failure looking at the pics.
How hard does he drive it? Would take a massive shock loading to snap that shaft...
  • Like 1
No, GTR are outright 6 bolt, plus stronger everything.
NA should be 2x3 6 bolters, like S chassis cars, with the weakest CVs. R32/3/4 turbos should be 5 bolt with the "medium" strength CVs.
I must be going crazy, Could have sworn when I was looking at driveshafts when I snapped mine the GTR ones were 3x2 but a quick search now it seems that they are 6x1. Going senile at age 25 it seems..... :S haha
When I snapped mine I figured it was from excessive axle tramp (the initial fracture) and a hard launch one day finished it off. It was a very similar failure to yours. This was on 195rwkw with 19" wheels and 265 wide rear tyres. I now have near 300rwkw and 18" wheels with 265 tyres and Havent had a driveshaft problem since the first one. Mind you I dont go dropping my clutch and doing skids
Any pot holes or rough road when it happened?
Saw a gearbox break recently due to this, going onto power, car got slightly light and back down again over the roughness killing the box.
Never had a issue on the flat in the past.
As could axel tramp.
  • 1 month later...
  • 3 years later...
On 12/15/2014 at 5:55 PM, r34unit said:
post-99078-14186264603518_thumb.jpgpost-99078-14186264727933_thumb.jpgypost-99078-1418626504493_thumb.jpgpost-99078-14186265196841_thumb.jpg
Nice pics, very interesting break. I'm no expert but it looks like metal fatigue.
https://en.wikipedia.org/wiki/Fatigue_(material)#/media/File:Tender_fatigued_axle.JPG
If the replaced driveshaft was a used part a contributing factor could be that the unit was repeatedly loaded beyond its intended limit during its lifetime aswell. Similar to when you bend a paper clip at the same point until it eventually snaps.
Dark, corroded void near surface looks like it may also be a manufacturing defect but that's just assumption, could be just oil stain.
As to why coincidently passenger drive shaft failure may be to do with how the differential is transferring load, similar to how an open differential spins one tyre under certain conditions.
May only be far fetched and theoretical but hope this contributes to the discussion.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
