hi there i have a 1977 c210 that is running rough at the moment do they have general problems with there carberators , i have changed the coil / spark plugs / tested leads & next thing i am thinking of doing is overalling the carbie .
spoke to a previous nissan mechanic from tha seventies & he did nothing but bag the l24 motor saying that they where renound for wearing out cams due to poor lubrication system & said they where nothing but a hassel to work on.
i left his workshop thinking surely they are not that bad . i am a previous v8 ford / holden man & know little about early model skylines . any reply would be great cheers my77sky
the are awesome compared to what holden had at the time
remember the L6 engine was first used in 1969
so it is an old design and in front of tech than even todays LS V8 engines, OHC anyone?
the mechanic who bagged the L24 probably another holden or ford fanatic,
the l24 is pretty much an indestructable motor, reliable and simple..i never know problems regarding lubrication, or that wearing out
cams?? was he kidding. i have owned skylines which have done in excess of 500.000kms the cam was never
replaced..maybe this mechanic was approching the dementic age,
if you need to compare the holden vb commodore or the xc ford of that time compare to a c210 skyline
the quality is such that the holden or ford belong in noah;s arch..along with that stupid mechanic..
cheers to all skyline owners
  • 1 month later...
dear bro'S
i am newbie from malaysia...nice to know c210/c211 owners
just buy c210@180k sedan,car is slightly rusty ..send the car for bodywork and painting
i have question here
i want to take out my original axle and put drive shaft rear end,can i plug n play 180sx or rps13 rear end?
another thing is adjustable suspension...my frenz say can put 180sx or cefiro a31,just need little modification..is it true?
thanks for the help
Edited by boxer_power
  • 3 weeks later...
Wrong Thread dude!
Try www.r31skylineclub.com
:thumbsup:
How is it the wrong thread? He has a C210, and clearly posted that he bought a front cut to transplant into said C210.
Welcome boxer_power!
yes 180 sx struts will fit with some minor mods, the front will require a bit more work than the rear, use the search function, there is plenty of information on the subject.
Cheers
Jason
  • 4 weeks later...
hi there my 1977 datsun / skyline is running like a clock now , a mate pulled the carbie off & it had some crap in it . looking forward to catching up with everybody at the all japan day at silverwater .
cheers my 77 sky
  • 3 weeks later...
  • 5 months later...
any
R30 diff is an R180(So is the C210's) but they are tuff as anyways...only reason to put an R200 would be for the lsd that is harder to get for R180's and for that lil extra strength if you are doing a LOT of clutch dumping with big rubber.....
Rear struts are straight bolt up....tailshaft is bolt up.the only thing MAY be the width of the rear subframe....but that shouldn't be a problem either.....
I have a complete rear clip for the r30 sitting in my shed ready for my C210 coupe.....havent measured it but cant see a problem( hang on,, im not tim.....I'll shut up now)
anyone can help me out with me pc210 skyline 180k?
my car comes with a rear dead axle and thinking to swap with a r30 r200 diff with lsd
when i got the complete rear end and i found out that width is slightly wider
any idea can recommend for me?fabricate a bracket to mount with it etc??
saw the first page looks like got few people managed to mount it lol
hope to get your help asap...
thx in advance
i recently put an R30 rear end in my c210. was a straight swap. the only difference i found was the handbrake cable between the discs is shorter with the r30 rear and the c210 one doesnt go back far enough to meet it.
I don't think you can install a IRS diff into a PC210, being live axle i would assume there'd be no crossmember or mounts for a crossmember for it.
Can you take pictures for us?
ok will take the photo when i am free
but i thought the chassis and undercarriage of pc210 design would be almost the same with sedan c210 (any version)
sad....no enough study before start modifying......
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
