Nah I won't be sticking with standard cams. Either gunna put in tomei ones or thinking about sending my head off to Lewis engines and getting the ultimate race head package.
Yeh I'm still undecided on what I'm gunna do yet so just got it installed anyways. The engine won't be getting installed for awhile. Still have to buy asr race sump, nitto oil pump, Ross balancer, 6boost highmount manifold, plazmaman plenum before I install it.
f**k looks like plans have changed again. Got f**ked over with the bloke building my engine so gunna start buying parts for a RB26/30. Will be buying a new rb26 head off justjap and nitto Pistons and rods this weekend. Just have to find a decent RB30 series 2 block.
Basically the engine I was buying/getting built the bloke talked abit if shit about some of the details on the internals nd I clicked on nd seen some evidence of scratches/marks on the Pistons but thought it was just the camera angle nd light but turns out they came from a engine that lost oil nd seized up bad so that explains the marks. Plus seen a ad on eBay from him with for a damaged rb25/30 so that tipped me over the edge to what he was doing. Trying to make his money back he lost on the original engine. No big loss only lost my deposit.
Gunna buy the rips complete rb30 forged bottom end now nd then get a rb26 head built by Lewis engines.
Just purchased a turbo from Hypergear there new ATR45 sat external gate. Have to send of my manifold to havoc fabrications to get modified for the external gate and screamer. I've decided to get this thing ready and on the track asap then I will concentrate on the 26/30 build. Sending the car off this week to get the sunroof hole fixed then will be sent of to get all the parts installed and tuned by Trent and chequered tuning.
Just picked up my new Hypergear turbo ss2 external gate with v band. Next step I will be sending this off this week along with stock manifold to havoc fabrications to get modified to run external gate and also get a screamer pipe, dump pipe and decat made up as well.
Dropped the car off at havoc fabrications tonight. Can't wait to pick it up once it's all done. Might be getting some extra work done while it's there. Door cards and maybe even getting a front splitter made up as well.
Yeh abe done so work on my daily and I was very pleased with his work quality. Stoked I've finally got someone to help me finish off the car to how I want it. I'm also keen to see what power it all make as well. Hopefully I can get close to the 350rwkw mark on e85. I'm ditching the power fc and upgrading to the Haltech platinum pro and getting Trent from chequered tuning to tune it.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
