No worries mate.
Thats all you can do really, i didnt get the choice, just got given peanuts seeings as the car was never found unfortunately.
Looking to see how you end up, secretly hoping you keep it streeted.
Sad not seeing many 32's on the road hahaha.
ah man that sucks. Hope you moved onto bigger and better things?
haha secretly there is a chance for that happening....
i already see more ferraris/lambos than 32's these days...
They are getting rarer! especially the sedans
That's because they are all in the shop with farked motors hahahaha
or wrapped around a pole or defected or or or ahaha :|
  • Like 1
Yea ended up with an extremely tidy 32 in the end for the lose of an HR31 Passage :( , but picked the 32 up for a bargain in the end so it all worked out.
Thread started last week or so http://www.sau.com.au/forums/topic/459637-daily-driven-1992-32-20det-kinder-suprise
Haha yeeesssss! Very excited. Will keep a keen eye on this thread.
i will keep an eye on your thread :thumbsup:
did a bit more work on it today. Headlights are finished and better than ever. I made up a custom shroud as before you could see through to the back it if 1" away haha (only i will notice the difference...).
Panels are off being painted and should be done shortly. After the it just needs matching LCAs put in and an alignment
Edited by CRSKmD
Saw this, and thought it looked a little bit familiar. Looks like your car has turned up on the "Adelaide Japanese Car Spotting" page.
https://www.facebook.com/304248339737355/photos/a.304570823038440.1073741828.304248339737355/502096826619171/?type=3&theater
haha yeah one of the first times i drove it and parked it somewhere!
Photo must have been old then. Most people that post on there, supposedly post their photo straight away.
sorry i meant to say one of the first times i drove it somewhere and parked it somewhere after the crash.
Photo was taken and posted the same day
cheers mate.
got a bit more done on it today and yesterday
Got din gauges and boost gauge in, R34 LCAs and new ball joints also fitted
Put some kilometers on it and do some track days.
leak down test to check motor health than maybe bigger turbo / external gate setup.
Cosmetically there won't be many changes though.
After over 2 years of knowing this guy AND both having Blue R32 four doors AND both being named Cameron. We finally got both of our cars in the same place at the same time and both running.
Edited by CRSKmD
hmm, they the same but look different, i'd take yours over the other though.. looks tougher :ph34r:
The other one is a GTS4 though :cool:
i do find picture of the front track difference funny :rofl2:
That really highlights how much better square plates are! Both cars look great man!
yeah square plates definitely suit it more
Suddenly last minute surprise track day
on the 12th of November i found out there was a spot in a private day at Mallala the next day (13th). I had realised that after putting in the R34 LCA's and getting an alignment i was now getting a bit of guard rub.
I spent the day doing Uni work as exams were fast approaching and only started to to do car prep at 5pm. I went to get a guard roller from a friend and in the same outing i ended up borrowing a harness from another mate.
I also bought a fire extinguisher because safety.
The reason i found out about the free spot at the track day was thanks to my Blue R32 sedan friend pictured further up.
In my first session i popped some cooler piping off and had to take the fornt bar off to put it back on
I figured I'd just leave the bar off for the remainder of the day and save myself some zipties :rolleyes:
The Goodride RS sport tyres id bought over 20,000km and a few track day ago held up well and while not being the best tyre for the track, they were a good match for my skill level. bit melty but held up well
First time driving at Mallala and first ever grip day. Had a good time and car performed well with minimal issues throughout the day.
Drove it there, hammered it, then drove it home. You can't ask for any more than that!
Video
Unfortunately the Go Pro went flat before my best part of the day. Here is some matched footage from my Dash camera and a mark 1 Go Pro
Sadly this footage densest seem to contain a clean lap. warm up/dirt derp/driver pass/coolerpipe blow off
Skip to 2:17 for dirt derp. While not having any intention of setting time i managed to average a 1:27 what ever that means for Mallala
  • Like 1
After the track day i thought i should confirm if the oil in my cooler pipes was from the motor or the turbo. so performed a quick compression test.
180+ psi and only +/- 5psi difference makes me happy. 3 years of NA+T life :rofl2: shout out to the people that said it wouldn't last 6 months +T'd
  • Like 1
  • 1 month later...
after the compression testing going well i wanted to get the full picture just in case. So I had a leakdown test done. Came back with extremely good results which meant i could go on to the next stage.
Before:
During:
12414073_10154550299359896_506084205_o_z
After:
NA is better :rofl2:
Edited by CRSKmD
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
