Okay fine, entered for Sunday. You all had very convincing arguments. Looking at the entry list, I will most definitely be holding up traffic. My car has also just got slower, took out the tune, lost 12rwkw which makes it go from slow to slooooooooooooow. Sorry, and my bad in advance.
Put me down for food Saturday and Sunday Ash, I think I'll head down on Friday and make a long weekend out of it :)
Haha good work Juliette :thumbsup:
Nah, it was occasionally throwing CELs and putting the car into limp mode so I cracked it and ripped it out. Might do it again with a different ECU and tuner at a later date when more mods would make it more worthwhile.
Hey guys, Im a new member this year and I was thinking about coming down for the Saturday to learn the track, I have a stock r33 gtr v-spec what are your thoughts on how the car would perform, is it critical that I do such things as upgrade the oil cooler?
I wouldnt say its esstential, but you won't be able to do as many laps before the oil temps get pretty hot
As long as you have an oil temp gauge to monitor your temps you'll be fine
As a guide on my stock GTT no oil cooler i got about 4 laps at Sandown before oil temps got above 120c
1. Ensure you have oil temp gauge.
2. Ensure you over fill the sump by 1 Litre before attempting track duties.
3. Ensure all other fluids are topped up and good to go
4. If brakes are under 30% pad, fix that up.
5. Ensure you READ the supp regs and sort things out like Fire Extinguisher, Battery point markers etc.
Otherwise you should be good to go. Long term it would be a good idea to sort an oil cooler and pay some attention to better brakes if you've not done half decent pads/rotors as at tracks like Winton you're gonna have a tough time.
There is sooooo much experience in the SAU-Vic track group, it's the best place to come if you want to do some laps in a Nissan. And if there isn't someone that can't answer your questions or help you out, then you've got something really wrong and should probably start worrying :P hahaha
Most all though remember to have fun as that's what it's all about. There are no heros at our events, just a bloody good bunch of guys so make sure you find the banners and come say a g'day.
  • Like 1
It's not an SAU track day without people scrambling to add upgrades and put their car back together in time :D I'll see you guys at a few rounds this year hopefully... won't be at PI though.
sure sure, you said that last year, year b4 and I think maybe the one prior to that...(or was that turbo gasket year)
Ha! you're one to talk Martin...
car saw the track briefly last year, a few early the year b4.
Entered our Motokana this year and waiting for the SAU sandown entries to open...
so to quote this dude who used to turn up to track days
cool story bro.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
