Squires Loft Nunawading BBQ will be in attendance again this year for Motorsport Rounds where possible :D
Doh, can't make it, so looks like I'm going to miss out on a good feed as well as a run at PI
Does it cost anything to just to come down and spectate? Is there good parking spots for spectators?
can I park up inside the venue someplace?
also nismoid don't forget to add artichoc to the sunday list with me, cheers :)
Gonna be a hot one over the weekend
Do we have a garage sorted yet?
Wheres the best meeting point before hand?
Was thinking the Macca's/Coles servo on the left straight after getting off at the Monash on to the South Gippie Freeway.
Scrutineering begins goes from 7:30 to 8:30? Takes 1 hr 15mins to get there from this point
So meet there at say 6:15 a.m? Or too early :wacko:
What about United Cranbourne since it's the last spot for E85 before PI? I think it might be a little out of the way for some people but I'll be there at 6:30am.
Happy with that, im on e85 too. Cya there :thumbsup:
  • Like 1
UPDATED Squires Loft Nunawading BBQ LIST
Please confirm if you are not on the list!!!
Remember the BBQ is FREE for SAU-Vic members only, get those memberships in - support the club that is supporting you!
Saturday
r31nismoid
matlowth
ripper_bravo
Snowman
acsplit
Odium
FINER6
miniwog
llama_au
Mick - MiColour
Total - 10
Sunday
r31nismoid
matlowth
ripper_bravo
Snowman
acsplit
Odium
FINER6
llama_au
vetter2769
arctic-choc
Tony Olsson & Robyn
blah_blah
Brett SS
Borci88
miniwog
Richo +2
atko92 +1
gtr jet +1
Mick - MiColour
Total - 24
Green_S13 - you still don't have a membership tag! Get that membership sorted.
jayjayjay - same as above
INXILE - same as above/above
Suggest you boys flick off an email to Anna: [email protected]
I did the last round of member updates this morning and none of you boys were on it!
Looking like a MASSIVE weekend for SAU-Vic Motorsport. Great start to the season
Flick off email to Anna :)
You would've have a forum tag if you were not paid-up. So that's ok... You sometimes need the sticker for CAMS though (when they check cards)...
That reminds me, NFI where mine is
  • Like 1
Hey guys Saturday will be my first race meet, just to confirm is there anything extra I need to get my car on the track other then
Blue triangle to locate battery
Tyre valve caps, ( plastic or metal ? )
Fire extinguisher with metal bracket
Car number ( can I write this on the window )
Car in roadworthy condition, full length clothing and Helmet.
Any advice is much appreciated.
Tyre valve caps, ( plastic or metal ? ) Metal are generally prefered
Car number ( can I write this on the window ) PI will supply you with a number when you sign in
What you've listed is just about all you need for the day.
Then it's just tools for maintenance throughout the day + something to check tyre pressure.
Also food and drinks if you don't want to purchase stuff from the canteen.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
