Squires Loft Nunawading BBQ will be in attendance again this year for Motorsport Rounds where possible :D
Doh, can't make it, so looks like I'm going to miss out on a good feed as well as a run at PI
Does it cost anything to just to come down and spectate? Is there good parking spots for spectators?
can I park up inside the venue someplace?
also nismoid don't forget to add artichoc to the sunday list with me, cheers :)
Gonna be a hot one over the weekend
Do we have a garage sorted yet?
Wheres the best meeting point before hand?
Was thinking the Macca's/Coles servo on the left straight after getting off at the Monash on to the South Gippie Freeway.
Scrutineering begins goes from 7:30 to 8:30? Takes 1 hr 15mins to get there from this point
So meet there at say 6:15 a.m? Or too early :wacko:
What about United Cranbourne since it's the last spot for E85 before PI? I think it might be a little out of the way for some people but I'll be there at 6:30am.
Happy with that, im on e85 too. Cya there :thumbsup:
  • Like 1
UPDATED Squires Loft Nunawading BBQ LIST
Please confirm if you are not on the list!!!
Remember the BBQ is FREE for SAU-Vic members only, get those memberships in - support the club that is supporting you!
Saturday
r31nismoid
matlowth
ripper_bravo
Snowman
acsplit
Odium
FINER6
miniwog
llama_au
Mick - MiColour
Total - 10
Sunday
r31nismoid
matlowth
ripper_bravo
Snowman
acsplit
Odium
FINER6
llama_au
vetter2769
arctic-choc
Tony Olsson & Robyn
blah_blah
Brett SS
Borci88
miniwog
Richo +2
atko92 +1
gtr jet +1
Mick - MiColour
Total - 24
Green_S13 - you still don't have a membership tag! Get that membership sorted.
jayjayjay - same as above
INXILE - same as above/above
Suggest you boys flick off an email to Anna: [email protected]
I did the last round of member updates this morning and none of you boys were on it!
Looking like a MASSIVE weekend for SAU-Vic Motorsport. Great start to the season
Flick off email to Anna :)
You would've have a forum tag if you were not paid-up. So that's ok... You sometimes need the sticker for CAMS though (when they check cards)...
That reminds me, NFI where mine is
  • Like 1
Hey guys Saturday will be my first race meet, just to confirm is there anything extra I need to get my car on the track other then
Blue triangle to locate battery
Tyre valve caps, ( plastic or metal ? )
Fire extinguisher with metal bracket
Car number ( can I write this on the window )
Car in roadworthy condition, full length clothing and Helmet.
Any advice is much appreciated.
Tyre valve caps, ( plastic or metal ? ) Metal are generally prefered
Car number ( can I write this on the window ) PI will supply you with a number when you sign in
What you've listed is just about all you need for the day.
Then it's just tools for maintenance throughout the day + something to check tyre pressure.
Also food and drinks if you don't want to purchase stuff from the canteen.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
