10333556_787761031312123_439263898279246
Saturday January 17th 8:00am to 8:00pm
Sydney Motorsport Park
For More info about the Nulon Nationals check out their facebook page
https://www.facebook.com/nulonnationals
Come and join us for the first round of the 2015 Nulon Nationals held at Sydney Motorsport park. A Gymkhana style event like no other, 7 different head to head courses designed to test event the most ballsy drivers, Finished off by 1 huge course at night to finish the event and have a bit of fun with our cars, Spectators are more than welcome and it will be free of charge.
For Nulon Nationals Merchandise click the following link https://nulon.selz.com/
10423925_802528129835413_361673725577642
Please come and support the SAUNSW team as they dominate all!
Our Team Members for this round will be:
Eric in his clean R33 GTR
10906037_816700481751511_754041913660458
Alex in his Stagea. Don't be fooled by the Grocery Getter appearance though, this thing can get around a woolies carpark pretty quick
10885193_790134404368296_842832381339727
Tim in his R34
10298232_784306454951091_770790676294045
Dave in his newly revamped R34
10325392_678842408830830_295853600890345
and Duncan in his mighty leaf!
https://www.sau.com.au/forums/topic/452732-nulon-nationals-2015-round-1-smsp/
Its going to be a cracking day guys... Racing from 9:00am until 5:00pm, at that time we will introduce 1 big course that takes the whole pan up and give each driver 1 crack at it... "One hit wonder" will sort the men from the boys.
Great attempts at beating the opposition yesterday guys.
Trivia From A Tent:- "They look just like my Mum and Dad; wandering off the road and onto a track where they shouldn't go" > 20 sec later, "Oh sh!t, they won!!!"
Congrats Duncan and Kel for orchestrating that one!
It was great fun running against some strong opposition and looking over at the end to see you slid into the pit a couple of seconds ahead!! The heads up is good competition.
Wasn't too happy on the courses that had cars heading towards each other...
WHAT A DAY!
Thank you to the team for putting on a great show and to everyone who came out and supported the team.
Also a big thank you to Nulon for putting an event like this on, hopefully everyone will get behind Nulon and buy some of their products, so they keep putting this on.
If you want to see behind the scenes of the Nulon factory, have a look at our members only technight we will be holding on 11th February, thread is in the event section. It's not to late to become a member!
Excitement levels went up when our guys came out, here are some of the photos I took yesterday.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
