haha i had another guy ring me after seeing it out front yesterday aswell :P
doing more summer prep, tint has been booked in. dash mat in place thank to you adz
also replaced the metal nismo gearknob with the leather version thanks to wantGTR.
  • Like 1
Well would you look at that. Glad its gone to a good home.
Are you still chasing a hard pipe kit? My mate has one for sale. A full greddy one off a bnr32
yeah i probably should get that sorted soon, got a link or anything?
I have narrowed an issue with an rpm hesitation i have been having down to the TPS so im getting that sorted tomorrow and i will also finally have a GTR back seat to go in (embarrassingly been using a gtst back seat up until now)
I'm gonna go on the SA GTR cruise this weekend to give it a proper drive, if the tps sorts the problem out i will get back to modifications.
turns out the other TPS we had was the wrong one, so to see if we could fix the issue we took the old one out and cleaned it up. testing it it does have a dead spot which we managed to get rid of, we tested all other sensors which were all good. put it back on.
now it has made it better but its still not right so we have ordered a new one anyway, its obviously just not right and there cheap so yeah.
interestingly it has created another issue, if i rev reasonably hard, say over 4000rpm and let the revs drop out of gear, it drops right down to stall, hoping this is just due to the dud tps, but we shall see when the new one arrives.
i did managed to take it for a good drive with some other SA GTRs which was good. car performed really well, the dead spot is between 2500-2800, somewhere in there so hard drivings not an issue.
also pulled my finger out and washed the GTR back seat i got from Josh and got that in. f**k i hated the gtst seats someone put in it.
yay
i know i probably shouldn't be that exited about a back seat but i am.
  • Like 3
  • 4 weeks later...
ok been a while since i updated anything. spent a week in bali for my 30th which meant the car was off the road for more than 1 day which never happens, so i took the opportunity to finally get the subframe pulled out and replaced the much needed bushes thank again to josh at Forge.
the original bushes are knackered and the subframe movement was getting to a serious point.
received_1274430752582898_zpsoryu5yoi.jpreceived_1274436109249029_zpsgo3f34k1.jp
check out how much movement there is. imagine this transferring through the diff on accell - decel.
http://vid30.photobucket.com/albums/c330/whitesi/GTR/received_1274573842568589_zpsqh1ia8y7.mp4
so, new bushes arrived and the subframe came out. new bushes, new fluids and a happy rear end.
received_1274436052582368_zpskpl2nqz6.jp
rear end is obviously much tighter and much nicer to drive.
also had the intake modified to remove the turbo shuffle thank god.
Edited by GH05T
  • Like 1
also, i have been ...slowly... being lzy... but chasing down the slight hesitation issue and i have been blaming the TPS... which i still do. but i have also just discovered that my BOVs are venting to atmo.... so yeah... might need to just fix that up :P
  • 4 weeks later...
Haha, just at work. Shitty plastic on a cheap head deck. So i have bought the same head ubit i loved in my stag which was a really good media player that you could plug a massive hdd into and it also had a wicked clock :P
Also got a full set of alpine r type speakers, 3 ways for the rear and splits for the front aswell as a small 10" sub in a sealed box (for hard kick over droning bass) and amps to run the lot. Should be a bit nicer than..... well... nothing.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
