haha i had another guy ring me after seeing it out front yesterday aswell :P
doing more summer prep, tint has been booked in. dash mat in place thank to you adz
also replaced the metal nismo gearknob with the leather version thanks to wantGTR.
  • Like 1
Well would you look at that. Glad its gone to a good home.
Are you still chasing a hard pipe kit? My mate has one for sale. A full greddy one off a bnr32
yeah i probably should get that sorted soon, got a link or anything?
I have narrowed an issue with an rpm hesitation i have been having down to the TPS so im getting that sorted tomorrow and i will also finally have a GTR back seat to go in (embarrassingly been using a gtst back seat up until now)
I'm gonna go on the SA GTR cruise this weekend to give it a proper drive, if the tps sorts the problem out i will get back to modifications.
turns out the other TPS we had was the wrong one, so to see if we could fix the issue we took the old one out and cleaned it up. testing it it does have a dead spot which we managed to get rid of, we tested all other sensors which were all good. put it back on.
now it has made it better but its still not right so we have ordered a new one anyway, its obviously just not right and there cheap so yeah.
interestingly it has created another issue, if i rev reasonably hard, say over 4000rpm and let the revs drop out of gear, it drops right down to stall, hoping this is just due to the dud tps, but we shall see when the new one arrives.
i did managed to take it for a good drive with some other SA GTRs which was good. car performed really well, the dead spot is between 2500-2800, somewhere in there so hard drivings not an issue.
also pulled my finger out and washed the GTR back seat i got from Josh and got that in. f**k i hated the gtst seats someone put in it.
yay
i know i probably shouldn't be that exited about a back seat but i am.
  • Like 3
  • 4 weeks later...
ok been a while since i updated anything. spent a week in bali for my 30th which meant the car was off the road for more than 1 day which never happens, so i took the opportunity to finally get the subframe pulled out and replaced the much needed bushes thank again to josh at Forge.
the original bushes are knackered and the subframe movement was getting to a serious point.
received_1274430752582898_zpsoryu5yoi.jpreceived_1274436109249029_zpsgo3f34k1.jp
check out how much movement there is. imagine this transferring through the diff on accell - decel.
http://vid30.photobucket.com/albums/c330/whitesi/GTR/received_1274573842568589_zpsqh1ia8y7.mp4
so, new bushes arrived and the subframe came out. new bushes, new fluids and a happy rear end.
received_1274436052582368_zpskpl2nqz6.jp
rear end is obviously much tighter and much nicer to drive.
also had the intake modified to remove the turbo shuffle thank god.
Edited by GH05T
  • Like 1
also, i have been ...slowly... being lzy... but chasing down the slight hesitation issue and i have been blaming the TPS... which i still do. but i have also just discovered that my BOVs are venting to atmo.... so yeah... might need to just fix that up :P
  • 4 weeks later...
Haha, just at work. Shitty plastic on a cheap head deck. So i have bought the same head ubit i loved in my stag which was a really good media player that you could plug a massive hdd into and it also had a wicked clock :P
Also got a full set of alpine r type speakers, 3 ways for the rear and splits for the front aswell as a small 10" sub in a sealed box (for hard kick over droning bass) and amps to run the lot. Should be a bit nicer than..... well... nothing.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
