FIIIIIIIInally got the car tinted. why i didn't do that before summer i do not know.
anyway when they guys were tinting it they found that the top of the window was no longer sealing.
i knew the rubber was coming up, but the actual sealant between the window and glass has failed. water would be coming through it this winter OR, it would pop out... that would not be coos as its a genuine wiperless window and irreplaceable.
top ruber just falling away, would not reseat at all.
bottom edgings are shit aswell.
i plan to paint the car or at least roof at some point so i will be ordering a full set of genuine rubbers, seals and surrounds at that point, but for now i just need to make it functional.
window out, quick rust check, there are a couple of little spots but nothing that cant wait untill the proper paint.
this is the corner that failes, rust spot
We cleaned it all up and put some treatment on it and resealed it all up properly.
new seal
un sure what i want to do at the base, i have ran the seal under the old metal frames, i will be re-using these when i get genuine seals, but for now i have just left the tabs overlapping the new rubber, the only way it can be blended and sealed without genuine bits. it will do for now.
the little misfire reared it ugly head again, so i decided to rip open the afms,
the solder looked fine tbo, didn't seem cracked or loose.
f380e707-22c0-4961-bb2e-ddcca024ffda_zpsfc2cc972-1fd9-4ffd-a6c3-26301cb7ba5c_zps
but i re soldered them anyway, i honestly added the smallest amount of solder, and resealed them back up.
this is a shit job, cutting away sealant and trying to reseal them without it looking shit house.
but yeah, misfire completely gone, so happy when simple things work.
Edited by GH05T
  • Like 1
  • 1 month later...
haha, yeah their allot easier to tint without the wiper too :)
Flex fuel... maby, not for now.
remembering im still running a stock motor, stock turbos, stock injectors....for now.
pulled the spark plugs out for new ones, they are about 2+years old and looked healthy which is nice.
Josh at forge was nice enough to get me the haltech so we hooked it up. its got the tune from his stock gtr so it was drivable, feels sharper already, it will be booked in for a tune with Garage7 to get it up and boogieing. then I will look at new turbos-dumps-fuel pump-injectors - maby a new cam - yada yada... at that point I will look into flex.
it is no longer a daily so I can deal with the availability and added maintenance, so I should...
must resist using antilag with stock turbos :P
im very interested in the tune difference with the same boost from stock computer to the haltech. im not expecting more highend realistically but keen on the midrange. I will report back once its done to compare.
Edited by GH05T
Thanks man,
I'm eagerly awaiting a time i can get it into Garage7 for a proper tune, very keen to drive it finally knowing it has a proper tune. Up until now it has had its MINES ecu, while it had the 8000rmp rev limit on the box you just never know what its actually tuned for. like I said im not expecting more power specifically as I will essentially be running the same boost (depending of the AFRs it yields) of about 12-13 psi.
It made 258 rwkw last time which was quite respectable for stock everything except exhaust and pods.
im more hoping for the midrange and the sharpness and general driveability without being a rich pig like it was, and of course having the safety features the HALTECHs have so I can give it more without worrying so much.
just waiting for a booking now.....
Edited by GH05T
damn tune had to be moved to the 10th .... damn Anzac day deleted my day off which I didn't realise.... le sigh...
maby I should take this time and put a fuel pump injectors and a cam in it...................... you know...... for good measure...
  • Like 1
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
