Sau:nsw - Monthly Meet February - Sunday Morning Cruise & Breakfast
Hi John let me know next time you're planning to do RNP so I can take my bike out, I don't have any real decent shots yet of me on two wheels :)
Be at the same spot this coming Saturday 8 - 12pm weather permitting
I'll be heading south bound threw the natio this Saturday probley passing Stanwell around the 9-930 mark maybee a lil earlier, will be a black sky80 purple s14 green sigma and a few other random cars with me if you get some photos I'd be interested
Will pay for mine today thanks John.
(I was wondering where those fingernail marks on my A pillar came from. And now I have proof! And it wasn't because I was taking the wrong line!!!! :P)
  • Like 2
Lol Terry! Get o the other side of that perimeter line!
How's my fat arming form?
What a great shot; the way this car looks on the move is spectacular.
Well captured John!
  • Like 2
Received my pic today, full resolution looks great!
Hi Scott,
Give me a toot when you come through so I know its you:)
10378136_825614470820289_761192511784488
Hey guys just wondering who took this sweet shot ?
And can i please get a high rez copy?
Looks the same perspective as Ciaron's shot of my car.
Nice driving arm btw
  • Like 3
did jason post up his photos? i dont see them
nah this shot was used for the SAU texi add
it's so last month, it's already march! :P:P
when is next meet?
march meet is up now
gotta do something when i'm driving the skyline slow
Bob, The 22B has been given decent print space in February Unique Cars #372 on pages 86-87. Tell Geoff huh?
And Ciaron or Jason if you can email any available hi-res shots of the 323i and N1 on the Seacliff Bridge I'll very much appreciate those. Many thanks in putting yourselves out too!!!
Yep......... Got it, thanks Terry.
Great issue.......
  • Charger vs. 240Z
  • R32 GT-R 5 page feature
  • Subaru WRX STI 22B article
  • Prince Skyline 6 page feature
  • Japanese Buyers guide
  • Japanese Value charts
  • Japanese Snapshots
  • Torana A9X with (162 kms) 6 page feature
  • Mercedes Benz SL560 for old farts like us!
Cheers,
Bob.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
