Would you become a contributor of SAU?
102 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • 2 months later...
Damn... i just noticed the supporter pack Stickers are different! lol
What do you mean by no flood control anyway?
You can 'upgrade' your subscription to the next one up if you wanted.
Flood control is the time period between posts. Most users need to wait 30 seconds before they can post again.
Done! =)
Hmmm now i have 2 supporter badge on the left under my nick - can remove one?
  • 3 weeks later...
What better thing to buy with Christmas money?
In all seriousness, how long does it take to receive the stuff in the post after payment? Looking at purchasing within the next few days or so, just curious.
FYI the link about cancelling a PayPal subscription is now invalid on the "How to become an SAU supporter" page.
Edited by Burger
  • Like 1
Thanks, I'll fix that.
I'm on holidays atm, so packs are sent out within 2 days of receiving payment. :thumbsup:
During the working year I'm usually able to do a post run once a week.
  • 1 month later...
How much money does sau need to become profitable?
Is it a huge amount will it be possible to raise?
Do you guys no why the fourm is lossing money is it due to falling traffic. Or other outside reasons?
So after being a lover of SAU for 7 odd years and utilizing the wealth of knowledge contained, its about time I contributed financially.
I did try to join SAU SA a while back but it wasn't working so was unable to, i was meant to get notified if it got fixed but nothing as yet.
Anyway, paid my subscription just now and after payment in the 'payment successful' screen the contact details for SAU seem to be incorrect.
I can't believe that the email address has no 'e' in skylinesaustralia?
Keep up the great work guys, I would hate to lose such an awesome forum!!!!
Thank you
For anyone reading this and wanting to contribute, here is the link:
http://www.sau.com.au/forums/subscriptions/
and if you want it to be once off only. (not a subscription) follow this:
https://www.paypal.com/selfhelp/article/FAQ1067/1
We're getting new lanyards made with dates (ie, 'supporter 2016') but i'd love to hear of any other ideas?
I can't imagine the renewals will need more stickers, maybe we could substitute a sticker or two with something else?
Also, the new lanyards are better than last years, they are thicker with better attachment.
What about bottle openers?
Or, USB drives?
Whats included will of course be determined by the subscription level.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
