Just wondering what examples if crank girdle blowing out you have? Considering "Vlgod" split a block lengthwise under the head studs and the crank apparently stayed in after running absolutely heaps of 7 second passes with the block . block split with 70psi boost.....
This thread so much negativity. saying why do it why this why that. whats the point. reminds me of a inspirational speach i heard once.
"Dont Listen To The Naysayers"
"How many times have you heard that you cant do this, and you cant do that, and its never been done before."
"I love it when someone says it has never been done before"
"That means when i do it, it means that im the first person to have done it"
"So pay no attention to the people that say it cant be done"
So i say Keep it up. :D
  • Like 1
what Mathew said!
whatever happened to doing something different?
bloody hell, there's a dude building a torana hatchback on here with full r32 gtr running gear...
Let's see something original, some innovation and some skilled fabrication!
geez if he has the time and budget to do it i say go for it, i can't wait to follow the build and see the results.
or let's just be like a whole bunch of other modified skylines on here and not have anything unique...
  • Like 1
When you say you want to build something, you really mean throw money at something, right? Cause if you havent even run a tape yet, I would be surprised if you know which end of a hammer to hold.
School holidays already?
  • Like 1
Just quietly the R35's 4WD system is what makes it such a monster, and all the computers. If you can drop those in the 32 and you will have a monster of a car.
The engine by itself? Apart from people going "oh cool look at that" what does it bring to the plate?
Otherwise you can make just shy of 500hp with -7's on corn syrup. And that's on a standard Rb26....... Let alone bigger twins/Big single/stroke etc...
As much as i would love to see this be done, for the price? you could get a much better car.
  • Like 1
wow, judgmental much
but your right, those hammers are tricky
ill go watch a youtube video and see if i can get it down pat
well your right about the RB being a good choice,
but having said that, i think its been done so much we know exactly what will happen
i can even go online and find a dyno chart for the same turbo and cam setup ill prob end up choosing
if we dont push the boundaries we wont progress,
just a little background on myself, i design and build products for a living,
in my life, i always want to do something different,
some times i win and its all fun, sometimes it explodes and we have to learn from the mistake
Do it mate, seriously you will have a lighter motor that sits further back in the engine bay and have 3.8L out of the box, a few bolt ons and it will make big power with a responsiveness that any RB could only dream of, so except the cost its win win win
You probably should learn, you might need one, you know, because you don't know if it will fit between the struts or not yet...
Seriously, you make a thread on a forum about your big fancy plan, when in reality, you don't even have a plan.
Not saying it wouldn't fit... But if I was planning on spending a metric shittonne of coin on a massive swap job, that would be the first thing to do. Just to know exactly what I am dealing with...
GL anyway... I'm sure this thread will be 20 pages long before there is a pic of progress...
Edited by MagicMikeZ32
its amazing the response,
its as if people want this project to fail,
for you info Magic Mike
i already measured the engine bay of a stripped R32 Gtr
measured all the relevant distances from the surface of the bell housing area and the center of the flywheel and the front diff of the rb26
i bought a r35 bell housing so i can get the bolt pattern
got quotes for all the work involved
found all the guys to make the parts,
found the engine, its in another state, and before i waste that guys time with a list of measurements i need,
i thought i would ask the experienced guys on this forum,
i wanted to know if it has been done, or if anybody knew of actual hurdles,
all im getting is people telling me im stupid
which i said was the case in my first post
so what your saying is, i should know everything i need to know before i come online and bother you,
i thought this was an exchange of ideas and experience
  • Like 1
wow thats a lot of info
well ok,
it HAS to be AWD or its not worth it,
the diff ratios are the easy part, and CV joints are much more forgiving than people think,
the diff and hubs can be misaligned a bit and work fine, the whole point of the CV is the flexible transfer of the power, they have a range they can work with
the biggest question is will it fit, so jay-rod is right, we have to get the tape measure out
and i think people forget the "waste of time/money" expression was used before, on people who wanted to get 1000hp out of a 2.6L
and now guys are doing that all day every day.
in my mind a car with the same engine as a R35 but 200-300 kgs lighter is a MASSIVE incentive
just a small increase in boost on the stock engine some tuning and we might crack 10 seconds
and the engine would be relaxed and comfy so it will last longer,
then if it worked, a big IF, people would know that its possible and try other interesting builds
Sure sure mate. Good luck with that.
Over and out
Go Hard Or Go Home.
on another note have you even thought about where all the intercooler pipe work is going to go? like will it even fit behind the bumper or are you going to have to customize the radiator area /front structure of the car to make it work? wouldnt mind knowing your plans for all this. and TBH i think the Twin Throttle bodies are the least of your worries. as said above your going haltech and there capable for fly by wire systems...
i thought the haltech would be ok too,
but i rang haltech and they said i would need to convert over to a cable system
there is a way to go around this and keep the electronic throttles
but the 4wd system in the r32 will work better with a traditional TPS
this is what the guy from the ecu wiring company said
as for the inter coolers, i will make it fit,
the block is shorter and the radiator fan is gone the one i will use to replace it will be slimmer
there should be enough room for a custom setup
im pretty good with cad and i have a team of fabricators that are good at welding pipe working for me
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
