Hi all,
I'm going to be upgrading my auto r34 set up and I'm going to install some new gauges. What do people think about prosport gauges ? Also to install the boost gauge can I use any of the factory wires/ connections ?
Lastly does an engine oil temp gauge work for trans temp ?? I can't find any trans temp ones so I was thinking about using an oil gauge and sensor for it ?
Cheers guys
Cheers guys, was just a little unsure. Also oil temp sensor will work yeah ?
Also do I have to run new sensors for the boost gauge and normal engine oil gauge to work or can I tap into anything from the factory set up to save some time ?
Good chance the sensors will be different resistance, you need to put the prosport sensors in for the gauge to be accurate.
Do you have an oil cooler? I run mine in the hoses, same with the auto temp sensor.
Yeah good point. And I'm buying a bigger trans oil cooler http://m.supercheapauto.com.au/Product/Davies-Craig-Hydra-Cool-Transmission-Oil-Cooler-8-Cylinder-Universal/125648 and I'll run the sensor after it before it re enters the transmission but the engine cooling is stock
Basically.
Think about it this way (im going to exagerate alot here). If the oil coming out of the trans is 200 degres, and the oil going into the trans is 50 degrees, which would you rather know about?
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
