I spoke to a muffler bloke this morning and he reckons 4" could stop the turbo spooling as early as it does now ??????
Just want it too run sweet , with no shit :woot:
Then find someone who knows what they are talking about.
Don't ever ask a muffler man for perfomance advise, especially that clown
The easier gases can get away from a turbo the faster they can get through a turbo making the turbo spool faster
You would think they would know something about exhaust if they are in the trade ?
So you would have to step it up from the back of the turbo to fit the 4" down pipe
Hate farking cars :)
All but one exhaust guy I have ever met has had no farking idea.
Their industry is full of old wives tales.
Go ask any exhaust bloke to make a set of headers, and once he is done ask him what rpm band they were built for and do they match the cam choice etc...
Yes, if you look closely mine has that done to it
Someone who knows what they are doing will be able to fabricate a dump pipe to cat setup for you easily.
But what that muffler guy said is absolute rubbish.
Joe just posted as I was typing, but yes you have to step it up if look back to his pictures he uploaded.
When is your car going back to crd pete?
They have a couple of weeks with some Motorsports commitments , so some time after that.
If I get a local bloke to do the 4" down pipe and the Cat, is there anything I should make sure they do, does the down pipe have to be coated ?
Would I be able to sell the down pipe, shit it is new :(
Unfortunatly that down pipe is just about useless pete.. Probably the only one I've seen where its stepped down straight away..
Maybe someone who needs a 3 inch dump could cut the start of the flange off but chances are slim that it would for someone else's set up :/
I coated mine to keep the heat out.. More $$ though
It looks like that but I wonder if it looks like that because it is right up on the bend and I think bends tend to take some size of tube, but ?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
