I haven't yet needed/been able to to rev mine past 7000, maybe I'm driving too soft Pete!
Would be interesting, but I doubt it can flow much more air than it currently does at that rpm on a big capacity, hence why dump mod didn't change much?
I use do take MI e to 8.5 or 9k.
whichever the limiter was set at.
went good.
went good.
Before the build I could hit 10k with not trouble, because I was too slow to grab 2nd the first time I booted it :)
Even when the T78 was changed for the 6262 it was limited at 9.5k and no trouble getting there. I could never stop myself from testing it :/
Maybe there is also some cam adjustment for a bit more grunt as I do not need anymore than 7000rpm.
Can dialing the cams make much difference for response, there might be something left with a bit of tweaking ??
Still not responsive enough?
Shouldve gotten a M3 or C63 AMG with this amount of money.
Limiter a day keeps the doctor away. Gotta make sure its still there
I did not want another car, I like this one!
Dead a long time Mate , might as well do one really stupid thing in your life :)
That's why they limit them, so you can check it out when needed .
Should have got RIPS NZ to build you a 3.2L would still rev to 9000rpm :P
shoulda coulda woulda, but I didn't and what would I do with 9k , thats why I went this way. I did speak to them earlier but I still needed someone to pull it down and put it together and fix it if shit happens
No mate it will all be good, nice looking R that holds the road and goes pretty quick, early :yes: :yes: :yes: :yes: :yes: :yes:
Why?
The bottom end hasn't flung apart. The only possible reasons for the rpm limit are turbo restriction, or ignition issues, or potentially the cam settings.
All a bottom end has to do is stay in one piece, everything else actually makes the power.
  • Like 2
If I wanted big power I would have gone bigger bolt ons.
After I do the fuel mods and flex tune I can bump it up if I ever wanted without costing and arm and leg, because I have already spent the arm and leg :whistling:
We aren't saying you did want big power. We are saying that the other guy is off point by suggesting another builder would have it rev to 9k with the same parts
  • Like 1
I understood what you said and even the 2.6 that CRD built that was in my car , was strong and rev it's head off, or your head off.
I believe the 3.2 motor they built me is as good as most.
It seems more blokes want the top end bigger power and I understand why, it is exciting when it kicks in and when you have the revs up.
I thought about doing some Hill climb events once the car was 100% and watched some more hill climb vids this morning, that was the end of that idea, they take it pretty serious and rip! Do they have any geriatric events or do they have a different class for the mug drivers ??
Ummmm not necessarily.
Why not, I guess it is what you think is expensive, poke in a new suitable turbo and maybe different cams dial them in and tune , E85 and away you go. I wish :)
I am not talking a 900 HP car but it should be pretty good
I have better expectations for mine as it is set up now and if it does not meet them I will change whatever.
To get it going set it for 2000rpm. There's your response.
SET WHAT ?, I take it you are joking and pulling my leg ?
If not, Do a Pauline, please explain :/
You know that I know nothing much about modifying cars, only what I have been learning while on SAU. I know more now in 18 months than I ever knew about cars and that is not a lot.
Up until now, I just buy them, drive them, brakes down someone fixes them, it was easy, only had to have the NRMA card with you :)
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
