Hi there first time post.
TL;DR Everything works good, specialist said that not enough fuel going into engine during spool/boost, is it common problem/suggested fix?
I currently have just bought an R33 GTST 1994 Skyline. And it drives great, I took it to a few mechanics and all have said its very very clean. It's only done 94000kms. One mechanic said he suggested new spark plugs and a 2 rocket gasket covers. So I got those done, only about 400 for the lot with labour. But I keep feeling there is power loss, I tried to explain to the mechanic but he said it was just me.
What I explained was that it felt like I could hear the turbo spool, but there was no power, for some reason it just felt like it was taking years for it go from 3000rpm to 6500rpm (7000 is my redline). Just felt slow. Mechanic said I was just thinking things. At first I thought it was boost leak, but he checked all hoses and piping, no leaks, the boost gauge also registers perfect as it should, all the way upto 11psi no jumping or anything.
The car has no misfire or idle problems. But recently a "specialist" who has owned one said that I was indeed right, there was something wrong with it. He said that he thinks up until 3000rpm, til before the turbo spools it drives good, but after that he thinks there isnt enough fuel going through, he said he checked my fuel pump and it was working, there just wasn't any flow. He also mentioned and i have seen this before, usually when similar skylines put the foot down you see more black smoke come out the exhaust because of the higher fuel flow, but mine doesn't get anymore smoke come out. So he suggested I might need to check my fuel pressure at the front where my engine is, get a tune, and possibly might need a new ECU.
The car has an aftermarket exhaust, just a hi-flow, not very big mufflers, I didn't put it in so I'm not quite sure 100% what brand or size it is. But it has an electronic valve controller as well, I don't know how to use it, it has a lot of possible settings, and was also curious if anyone knew anything about it? Could it control my fuel flow? here is some pictures of it, and all its settings - http://imgur.com/a/YsAwf is while the car is idling, and just pushing PWR to turn it on, and then mode to go through the set settings).
And also my HICAS light is on, but god knows what that could be.
Is there a way I can fix this without making it cost $3000+? Or is my mechanic wrong and should I look for/ask for something else? Maybe I should take it to a tune shop and get a second opinion.
Edited by Stoychevski
https://www.sau.com.au/forums/topic/455865-r33-gtst-possible-fuel-problem/
Its interesting you believe the car has actually only down that many ks.
Its odd to replace rocker gaskets at less than 100_000.
That specialist sounds special.
Go somewhere who knows what they are doing.
Welcome to the forums. Be prepared to read and search for ideas on the problem, lol.
Secondly get a second opinion or many more as you don't want to be spending heaps of cash on parts that aren't broken.
Most gtst's are definitely old (probably closer to 200,000km traveled) and run like dog shit so working out what the issue is could take time, be prepared for that.
FYI, add another 100000 or 200000 to your odometer.
My car says 146xxx judging from the amount of parts I have had to replace it's seriously got a decent 346xxx kms. A good give away for age are the castor rod bushes and all four tie rods/tie rod ends.
I bet they're loose as a hoe lol
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
