You had a go at someone because he owned a stagea..
^ This is the only thing i care about. Not sure why all these skylines and gtr's are on a stagea forum anyway..
Lol no i didn't.. I was having a dig and responding to his remark with sarcasm as he responded to mine.. don't take it to heart dude.. nothing wrong with a stagea only his lol
  • Replies 70
Lol Another know it all.. report it dude.. I bet you are the smartest kid ever all hail the genius that is Brett.. it's like no one is allowed to ask a question.. Some of you rude ass members need to deflate your big heads and if you can't contribute and discuss the OP then please refrain from trying to look like your all that because hey you better beleive it your not.. your actually acting like childish bullies. I truly wonder how many have left this site because of wanna be macho talkers in this site..and why don't you use the search button and look up forum?
i obviously know more then you for the fact I know how to use the search function and Google, so when you're able to do that you might be on your way to knowing as much as I do
Clap clap awesome come back.. lol.. but please just to prove to everyone how smart you are please share a link answering the OP.. If you can't I will suggest that we hail you the troll and just a pretender.
Find your own answers, I'm not here to do it for you
Does your mummy still have to wipe your ass for you or are you a big enough boy to do that yourself?
Ooow lol resorting to insults.. who's the trolling who bitch? Lol your obviously piss week.. and like I said no link you are now chosen as a pretender and a troll
.now run a long with your half wit comebacks
If you look above you post someone else decided to do it for you instead,
Btw it's piss weak not week
Lol ok your piss weak every day of the week?
And yes if you notice in that link the comments ..well they were constructive.. amazing ? And doesn't count that someone else found the link.. you are no doubt a troll and a pretender. . Who just likes to bag people's questions how tough of you
Edited by boobeedoobee
Nope didn't read any of them, don't care
To answer your next question, yes the bolts will loosen if you turn them anti-clockwise
I don't understand why you think I'm trying to be tough, I'm a whole 5'0" and weigh about 50kgs I know I'm not tough
remember that chat we had.. www.google.com
Jumps in at the end with another pointless remark why don't you Google dimwit and then do the opposite of what it suggests..
Keep on trying bobeedoobee. I'm sure that you will convince everyone that you are right and they are wrong.
Look over what I said. I've helped alot. You chose to get all weird.
  • Like 1
Hey boobeedoobee ... You might want to just cool down a bit.
You're trying to take on everybody in the thread!
? Edited by boobeedoobee
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
