You had a go at someone because he owned a stagea..
^ This is the only thing i care about. Not sure why all these skylines and gtr's are on a stagea forum anyway..
Lol no i didn't.. I was having a dig and responding to his remark with sarcasm as he responded to mine.. don't take it to heart dude.. nothing wrong with a stagea only his lol
  • Replies 70
Lol Another know it all.. report it dude.. I bet you are the smartest kid ever all hail the genius that is Brett.. it's like no one is allowed to ask a question.. Some of you rude ass members need to deflate your big heads and if you can't contribute and discuss the OP then please refrain from trying to look like your all that because hey you better beleive it your not.. your actually acting like childish bullies. I truly wonder how many have left this site because of wanna be macho talkers in this site..and why don't you use the search button and look up forum?
i obviously know more then you for the fact I know how to use the search function and Google, so when you're able to do that you might be on your way to knowing as much as I do
Clap clap awesome come back.. lol.. but please just to prove to everyone how smart you are please share a link answering the OP.. If you can't I will suggest that we hail you the troll and just a pretender.
Find your own answers, I'm not here to do it for you
Does your mummy still have to wipe your ass for you or are you a big enough boy to do that yourself?
Ooow lol resorting to insults.. who's the trolling who bitch? Lol your obviously piss week.. and like I said no link you are now chosen as a pretender and a troll
.now run a long with your half wit comebacks
If you look above you post someone else decided to do it for you instead,
Btw it's piss weak not week
Lol ok your piss weak every day of the week?
And yes if you notice in that link the comments ..well they were constructive.. amazing ? And doesn't count that someone else found the link.. you are no doubt a troll and a pretender. . Who just likes to bag people's questions how tough of you
Edited by boobeedoobee
Nope didn't read any of them, don't care
To answer your next question, yes the bolts will loosen if you turn them anti-clockwise
I don't understand why you think I'm trying to be tough, I'm a whole 5'0" and weigh about 50kgs I know I'm not tough
remember that chat we had.. www.google.com
Jumps in at the end with another pointless remark why don't you Google dimwit and then do the opposite of what it suggests..
Keep on trying bobeedoobee. I'm sure that you will convince everyone that you are right and they are wrong.
Look over what I said. I've helped alot. You chose to get all weird.
  • Like 1
Hey boobeedoobee ... You might want to just cool down a bit.
You're trying to take on everybody in the thread!
? Edited by boobeedoobee
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
