I trashed mine at a bar all day everyday for a year before it was stolen. It will break eventually. Just be prepared for when it does and thank god you don't have a 26 that takes the motor with it
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
