Hey all
Bought over the weekend this R32 gtst, manual. Now no laughing!!
Just to let you know i got it cheap! CHEAP! Runs well and drives nice.
Has more stickers on it then ive ever seen and to make things worse they have cleared over the stickers! and the pics dont do justice to how many stickers there are on the car!! but anyway!
Another problem is, its running duel fuel. Yep, 98 and direct LPG! actaully runs well on lpg....
Anyone ever seen LPG on a rb before??
anyway. the interior is not to bad just need to replace a few things.
Didtch the body kit on it, lower it and chuck on some wheels.
Just looking for a nice non defectable daily.
Have started chasing parts
Paint will come later
11072496_10155518900265215_8764080191540
11148592_10155518900195215_7138532922615
  • Like 2
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/
Haha yer im unsure at this stage what ill do... take it off is the long term plan.... short term is to dig in and get it looking presentable, because it runs and drives really nice.
But all of this has to be done on a budget, and most will be done by my hand.... May have bitten off more then i can chew! As the pics make the cars interior and body work better then what it is! Yes really!!
Edited by Adz2332
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525617
Yep thats this weekends job. pulling out all the white stuff sanding and painting. matt black?
Also pulling out the seats, front and back as carpets look good but will get the steam cleaner into it... and the speakers etc are a mess! so again will pull all the speaker stuff out and put some of my own stuff back in.
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525626
I'd be tempted to paint the trim gloss metallic black.
Grab a couple new vents for the dash... and a stock GTR wheel.
... aaarh bodywork. maybe smooth it off and wrap the car?
gloss might have a look. wait till ive fixed them and rubbed them back etc
Ive always wanted to have a crack at spraying... but thatll be long term.
Vents are a pain to come by!
Strip the whole thing and track it.
hahah already have a track car
Think the 32 has 4x4 springs in it!! lol
Edited by Adz2332
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525727
have 2
  • Like 1
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525730
might be selling/ giving away 32 gtst seats soon, also might be selling my 17x9+22 enki wheels with good tires.
if you keen ill let you know when.
i have a spare stock handbrake boot too.
how do the rims sit? would be interested if they dont poke... dont want to be defected lol. main MAIN aim for this car!
https://www.sau.com.au/forums/topic/456114-daily-r32-gtst/#findComment-7525883
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
