Hi gurus,can anyone tell me why I have to replace my exhaust Mani every 3 or 4 years due to cracks,getting a bit boring now.Coming up to my 4th one this year,any way of sorting this I know I do a lot of ks every year 30000 plus but its mostly long hwy trips pissing me right off it is. :-)
https://www.sau.com.au/forums/topic/456126-cracks-in-exaust-manifold/
Reweld it ?
Or buy a good one ...
Rewelding it id a waste of time and money considering how cheap another stock one is..
Its the heat cycles that kill them.
Do you get in the car and give it a hard time straight away or let it warm up first? If you even give it a hard time!
Reweld it ?
He asked why it cracks.
I can only imagine it's getting hot possibly because always on boost on the freeway and it's tuned? Everyday on boost for hours would take it's toll on a lean tune. Only speculating though.
Ha ha,I never thrash a cold engine on any car,I warm up for 20 seconds then drive sedately till it gets to operating temp,
then drive it like I stole it , :-) :-)
Safe PFC tune 220 at the rears for many years now perfect afrs. PS me lady lil ol lady. :-)
My mechanic is the one doing the work I assume he uses a torque wrench to the right specks.
I'd be speaking to him then; don't assume. Check what gaskets you're using too - those cheap cardboard-ish ones don't transfer heat well, and like to leak.
EDIT:
Also, check that you have the front exhaust hanger installed at the gearbox cross member, it's the only real form of support the turbo has. Even without it, it shouldn't really cause cracks on the manifold.
Edited by colourclassic
  • Like 1
Thanks heaps guys,my 33 is serviced every three months,and up on the hoist as well I like to be safe,I'll chat to him when I get back from brissy in a couple of weeks.Far as I know exhaust supports are all there in good condition.I'm just thinking there must be a reason for the Mani to crack have to find out why. :-)
Are you running a flex pipe in your dump and has your dump got a solid mount to the body near its flange like the std ones do? they play a big part in saving manis, gaskets, loose bolts etc.
^^ This. The exhaust is a 5m long breaker bar, and your manifold is very soft at that temperature. A flex join in the front pipe isolates the forces caused by your muffler swinging around.
  • Like 1
I used a few of these as exhaust mounts:
http://www.ebay.com.au/itm/Toyota-Landcruiser-HZJ80-HDJ80-Series-Exhaust-Mount-Rubber-Set-3-/201205416170?pt=LH_DefaultDomain_15&hash=item2ed8c700ea
Had to fabricate my own brackets, but they make a great semi rigid mount. The exhaust cant swing around anymore.
My exhaust grows in length by 1 1/2 inches at the track, I would be surprised if those would give enough movement to last long term, unless the bracket can bend...
Later model Nissan cars have a fixed rear bracket to stop the muffler swinging around, but they still run a flex joint stock.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
