Are the rubber mounts an option for road going cars or is there a reason I'd choose those over the spherical unit for a track car?
http://www.hard-race.com.au/index.php?route=product/product&path=25_29_355&product_id=418
VS
http://www.isccoilovers.com.au/nissan-castor-arms
Spherical work a bazzillion times better. Not really legal on the road, so sticklers for legality* would avoid them. For a track car, there is no argument for not using spherical.
*I'm a stickler for legality in most respects, but I used spherical bearing caster arms on my road car because of how much better they are, coupled with the unlikelihood of them even being noticed in a roadside pullover situation.
Only thing about spherical joints (apart from cheapo ones sometimes flogging out very quickly in certain applications) is that they generally aren't allowed in IPRA - if you decide to head in that direction. If it's just a track toy / WTAC toy then go your hardest.
The beauty of spherical joints is that they let the suspension move the way it was intended, so under load your geometry remains where it's supposed to be.
Thanks, not an issue for me thankfully.
I had someone tell me that ISC are junk, thoughts?
I have ISC rear camber arms and they "seem" fine.
The car doesn't do a lot of K's each year.
I didn't really wanna pay $200 for caster arms.
Choose wisely mate,,, I have seen factory radius rods break over time and wis-bang spherical ones snap as well.
Whilst the Spherical ones are more direct they have no give whatsoever,,,sooner or later they will fail.
Lifeing both would be the idea,,but the question if for how long.
Cheers
Neil.
Lifeing both?
Scheduled replacement interval. Work out how long you expect it to last, then replace them at an appropriate time (preferably before they fail). unfortunately, you need some failure history to be able to work out an appropriate life.
It is possible to crack test the items that are likely to snap (I have an MPI crack tester) and you can inspect the spherical bearings for wear. The latter is an easy check you can do, but unless you have access to the right people / equipment, crack testing becomes dearer than outright replacement.
Edited by warps
Ahh, my car is lucky to cover a few thousand ks a year - track ks granted, but still.
I assume inspecting the spherical bearing is as simple as giving it a yank and seeing what freeplay there is?
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
