The new NSX is almost upon us and it looks incredible.
Its a hybrid with a twin-turbo 3.5 litre V6 and a dry sump. As with the original GTR and NSX, this one looks much more "supercar" than the R35. Especially with its transparent engine cover.
The profile and rear look like a cross between a McLaren and a new Corvette.
The Acura model is being built in North America. I'm hoping that the model we get is built in Japan.
Basic details and a guess of $150k shelf price available on Road and Track.
I've included a pic of the NSX concept from 2012 which looks remarkably like the final product.
Check out the micro site on Honda.com.au to register your interest.
And, the concept;
What do you think?
  • Like 1
https://www.sau.com.au/forums/topic/456227-2016-honda-acura-nsx/
Wonder what it means for the next gtr? Hybrid too?
Nissan has all but confirmed that the next GTR will be a hybrid. http://m.drive.com.au/motor-news/2015-nissan-gtr-hybrid-confirmed-20131108-2x5wh.html
Most of the Prelude Australia guys (of which there aren't many left), think it's horrid.
I guess they're thinking this is too far removed from any Honda sports car appearance of former years.
At least Carlos Ghosn insisted on the afterburner lights on the R35 and from the side, the front end has the same bonnet shape as the R33.
I like the idea that the future R36 will be pared down to 14**Kg.
Back on thread, this new NSX/Acura could badged as a Veloster Turbo and I'd believe them. And that's despite the fact that I like Honda engineering...
  • Like 1
The meeting, they look like they're trying to go Lamborghini-ish with their styling.
Trying to get into supercar territory.
I don't mind it, but for the price(let's face it, it's going to be very exxy) I'd possibly look at said lambo.
I think Honda haven't made another future classic here, it will be a car that just fades into the past due to it's extremely generic look. They just bowed to the norm of aerodynamics today and threw out most traces of the past. There will always be the Honda fanboys loving it though.
When the new GTR was first shown off why did everyone get so horned up over it and why has it been so successful?
I don't mind the look of it, and I reckon it will be a decent performer (but then again I'm a Honda fanboi)
The biggest problem as I see it is that the original NSX was such a surprise when it hit the market - nobody expected the levels of performance from it. That's probably the main reason it's gained the level of notoriety / status it has. Now that the element of surprise is gone, everybody is expecting another giant killer. If it achieves this, then it's a case of "yeh, so what"? If it doesn't deliver giant killing performance, then it will be remembered as a dud.
Not an easy task.
  • Like 1
^Yup. It's like trying to follow up a killer debut album. The original NSX is the Appetite for Destruction of the motoring world. My biggest fear is the new NSX is the "Axl Rose world tour" of the motoring world.
  • Like 1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
