I think most of it has already been mentioned.
At the moment the US is relatively undeveloped as a market, so they're buying the kind of cars that we would generally reject - heavy accident, tampered odometers, rusty etc. Plenty of JDM wood-ducks for the exporters to burn before they start to wise up over there. With the exchange rate taking a dive, cars ex-Aus are looking more and more attractive, but the US would rather buy crap and keep prices landed in the US under $20K there than worry about quality.
The market will start to develop though, and as time goes on, buyers will be looking for clean cars globally, and paying big dollars for them.
It's the same phenomenon that has seen virtually every 240K coupe disappear from Australia, mostly to the UAE.
Most collectible sports cars go through a depreciation cycle, then rise again. In Japan, prices of clean 32s started climbing about 7-8 years ago. Clean series 3 R33s have also been rising for a while, and R34s hit the bottom of their cycle about 5 years ago too.
Australia's cycle is a little longer, so we're only starting to see the rises occurring now (although demand from the US is speeding that process up). If you're buying locally, look for clean late model R33s and clean, genuine km R34s as they're money in the bank as far as I'm concerned.
I'm hoping to send my N1 to the US in 2026, in the hope it will fund my retirement ;)
The Relevance of THIS ^^^
...should echo within the craniums of every Australian who owns a GT-R; and not just a BNR32.
Thank you Kristian for your feedback :yes man:
PS I never noticed how tall you were.
  • Like 1
  • 3 weeks later...
  • 4 weeks later...
I'm in the process of trying to find one. I have Troy from Iron Chef looking in Japan. Its been a couple of months now with barely any luck.
I've been looking for a 4.5 with less than 60k and have a fairly decent budget but am getting 1 car a week, if that, and most seem to have really low km (under 20k) and seem to exceed my budget.
I have only considered one car in Aus and that was the gunmetal nismo edition that sold a few weeks.
I'm too impatient for this... I guess the search continues
Oh and if anyone is thinking of selling, please let me know.
  • Like 1
There's a guy in WA on FB/gumtree who reckons his is pretty nice... Price is pretty "nice" too. lol.
http://www.gumtree.com.au/s-ad/bentley/cars-vans-utes/1994-nissan-skyline-r32-gtr/1089642050
dont like the climate control relocate.
no holes drilled through speaker mesh is a plus i guess.
edit: still 4 years until that one can go US...
Edited by okooko
I've seen that one, not a big fan. Too many bits and pieces I'd remove and its boosted...
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
