Won't be until next years christmas holidays i reckon. Wifey wants to start trying for kids pretty soon so that will slow things down
[emoji171] Pregnancy is a wonderful miracle, and in nine months your joys will double. Congratulations for getting yours x
Japan is our very first honeymoon hope it goes alright [emoji28] but Darling Dave mention about the capsule hotel? [emoji33][emoji35]
Haha I like the sound of Dave.
Capsule hotel and everything is 5 minutes away ;)
Capsule hotel and everything is 5 minutes away [emoji6]
[emoji34][emoji57] I won't mention to him that capsule thing is close to where we staying [emoji14] [emoji122]?
4 minutes ago, Manne said:
Everything is fixed on my car...except the door. No one has the front left passenger for a 4door apparently. Going to start calling around myself and see what I can muster up.
If only you had a 32 sedan, i have 2 spare sets of doors
Looks as tho that rolling body i sent to you is gone but just saw this looks awesome
Please view this ad:
Mspec r33 skyline rolling shell,
http://www.gumtree.com.au/s-ad/calamvale/wrecking/mspec-r33-skyline-rolling-shell/1118547628?utm_source=com.google.android.apps.docs&utm_medium=social&utm_campaign=socialbuttons&utm_content=app_android
Price: $1,500
Download the application from the Google Play Store.
http://goo.gl/7NzhP
15 hours ago, Manne said:
Hey Lachlan...need some one to do a nice detailed wash on your RX-8?... i'm free tomorrow....$50...
Haha, it's under the car cover. Thanks anyway bud :P
:O
Only wednesday here. Piss up tonight at a new mechanical shop around the corner. Might spew all over there nicely painted floor to make a good impression
I remember when Galvsport opened his new workshop, he wouldn't let us do burnouts on the workshop floor prior to painting, worst :(
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
