Hi guys,
Hoping for some thoughts on this.
i've replaced my factory radiator with a new 40mm alloy radiator and now my coolant temps don't want to go above 75 C.
i've been reading up about replacing the clutch fan with electric but i'm happy with the clutch fan for simplicity (street driven car)
bearing in mind its winter here in NZ, should i just not worry about this and suck up the slight increase in petrol consumption or are there any alternatives?
i was thinking perhaps an R34 thermostat instead of the r33 thermostat?
i'm not opposed to electric fans either.
cheers
https://www.sau.com.au/forums/topic/456949-new-radiator-now-better-cooling/
Just try a new R33 thermostat first. Many years ago I did on my RB20 exactly what you just did. Only replaced the rad because the end tank cracked - not because (I thought) I had inadequate cooling. The result was that the coolant ran cold and I used a heap of fuel. Put a new thermostat in and the problem went away.
What was actually happening is that the old thermostat was actually no good - stuck open, and the radiator was also not real good. Must have been part blocked or something. It wasn't doing enough cooling and the two of them together were actually keeping my coolant temperature in about the right range. Replaced the rad and threw that precarious balance out!
  • Like 1
I bought a new 82c thermostat and it's clearly 65ish in the real world. I wouldn't be surprised if the Nismo thermostat is actually the 'new' standard thermostat that gets sold.
At least that's whats happened to me... from buying new thermostats trying to get one that's better/higher/more suitable? than the 65c one that seems to always end up in my car.
.. different radiators, too.
What's the idea of a lower temp thermostat? It doesn't increase cooling capacity at all and at best would buy you an extra lap maybe 2 if you're having heat problems
For the nismo whores.
Sort the real issue out, don't band aid it.
Nismo thermostat runs a higher temp but your right, a normal thermo should still operate properly.
why would it run a higher temp? lol
R34 thermostat opens at 82 degrees so your water temp will be close to 90
R33 thermostat opens at 77 degrees so your water temp will be close to 85 or so
I prefer to run a lower temp one simply because when you're on the track there's a greater range before water boils. I'm using a 62.5 thermostat lol... but that's no ideal for a street car because your oil temp is too low (even if you have an oil thermostat as the oil temp is relative to the water temp due to the heat exchanger).
Also R32/33/34 thermostats are the same size... I made the mistake of fitting a R34 GT-t thermostat in my R33 and kept on scratching my head on why the water was always close to 90 degrees.
  • Like 2
what water temp are you trusting here?
stock sensor and gauge?
In my case, stock sensor and gauge, aftermarket sensor and gauge, and the ECU temp sensor and gauge (via the ECU program)
I got an oil temp sensor and gauge specifically to see what my oil temp was, because I was certain it either wasn't 65C, or if it wasn't... to find out what it was.
I put a Nismo Thermostat in my R33, it now sits bang on 68 degrees no matter what, until I start putting my boot in. Then the koyorad keeps it below 95c even after 4+ hot laps on the track...
Only issue is it is TOO cold... my tuner had to adjust the powerfc water temp adjustment data, because he was needing to spend time on the dyno trying to warm it up so it would be running in the correct parts of the maps for power.
i've replaced the thermostat with some success, the temp now comes up past 75 and makes it to 78 but stays at 78, this is good i guess, its winter and pretty cold here at the moment so i won't worry about the enrichment, haven't given it a death thrash yet....lost a bit of skin on my knuckles changing it....
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
