Hi Guys, my name is Lachlan, Im 20 years old from Sydney, and Im writing a build thread for my car to keep you busy during work, as well as help me keep track of my progress with the car. Before I get started, I'll provide a bit of my car history.
My first car was a 92 Honda Prelude, which started life granny spec with hub caps and all. By the end of its life it was looking like this
I loved that car, it was efficent, handled well and was perfect for my P's, but unfortunately it got T-boned at an intersection one night. The next day I went and bought my Skyline. I also had a SR400 Cafe Racer for a while which got me around as I couldn't drive my new turbo car for 4 months since I bought it!
I found the Skyline on Gumtree and from the second I saw it I needed to own it. I got it for a good price and it came with a roadworthy certificate. It is a 1993 GTST Type M with 130,000km's on the clock. The bloke said it was a personal import and that he bought it for his daughter before realizing she couldn't drive it on her P's. It came with a full GTR body kit including alloy bonnet, side skirts, wing and rear pods. It also came with a lightened flywheel and solid mount gear box bushings, HKS super sound blow off valve, turbo timer, 3' turbo back exhaust, (Splitfires - we'll get to that later) and brand new Pirelli P-zero's. Apart from that it was basically stock. I got it for a great price and bought it home.
I got a permit to drive it unregistered and drove it over an hour home with no number plates legally. After getting it home it was obvious the car had been sitting for a long time at some point in its life and it was covered in some kind of over spray. I got my mate who is a detailer to have a crack at the paint and it came up beautifully, and then painted the wheels with VHT wheel paint and calipers with VHT metallic. I'd like to change wheels in the future but these are okay and the Pirelli's are pretty awesome. Also threw on some weathersheilds I got from Just Jap and some neo-chrome steel wheel nuts
So far I've driven the car for about 6 months and had my fair share of Skyline fun times. The first thing that went was the fuel injectors which had three leaking out the sides and needed replacement. I bought a complete second hand set and had them cleaned and flow tested before installation. I also had to change the clutch master cylinder as it decided to drop its guts on my carpet. I've stripped the boot interior and installed a decent sound system, and put in front and rear strut braces in which I cleaned up using left over caliper paint
I've so far upgraded to a Excedy HD clutch as the one in it started to slip due to the big seal going, and bought new Splitfire coil packs as the splitfires that were in it were actually red jackets which were rooted and causing misfires. I've also installed a HID kit, set the ignition timing and changed the 02 sensor which made a world of difference for acceleration and fuel economy. The ignition timing was way, way advanced and I think this was causing the most driveability issues. I've still got the usual idle issues but overall the car drives and runs great!
It also had a dodgy old fashioned wastegate bleed valve which was letting it boost like crazy, so I upgraded to a GFB electronic boost controller.
I've also done a couple things to tidy up the inside with a new steering wheel and replacing the gear and handbrake boots. Note the bubble-less dash!
The dash lights were completely blown in the climate control unit and the dash cluster ones were pretty average too. I upgraded these all to orange bulbs. The orange is awesome as it doesn't distract your eyes at night but is easy to see.
I'm learning a lot more than I ever thought I would about working on cars and I'm loving it more every day. Thanks a lot to everyone here on the forums who've taken their time to post how-to threads and put up with newbies asking all the dumb questions, you guys rule.
Future plans for the car include R34 NEO turbo, return flow FMIC, coil overs and a proper tune. I also need to install a catch can and would like to make the exhaust a bit meaner. Overall I want this car to be a good, reliable daily car which I can still have a lot of fun in. I'll keep this thread updated as best I can as I continue to work on and build the car.
Thanks for reading!
  • Like 1
https://www.sau.com.au/forums/topic/457223-street-serenitys-r32-gtst/
Cheers for the support guys! Really appreciate it.
My attempt at saving some money for other things failed miserably when some Tein Coilovers came up. They made their way onto my garage floor as well as some sweet camber arms I managed to get from the guy as well.The car had KYB shocks and decent springs in it but they were fairly worn out, and I'm 20 and the ride height just didn't cut it for me!
Sending her away for a wheel alignment this Friday, also changing the steer tie rod ends this week before the alignment as I noticed they're a bit noisy.
Pretty happy with how its coming together, now on the look out for a return flow intercooler and a new BOV. I'm pretty sure the Fast n Furious HKS BOV is leaking but its a antique so Im not surprised, it will have to go anyway when I replace the intercooler piping for the FMIC. Very low on funds now though so it might be a little while before you see an update from me!
Edited by streetserenity
  • 1 month later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
